VR Stack - Part #2
At part throttle your mixture is going to be 14.7:1 so long as you are in closed loop (this equates to an O2 sensor reading of .450mv which the PCM constantly tries to maintain during closed loop operation by way of the O2 sensors.) This is always going to be the case unless you program it differently. I would think Bauer knows this.
At WOT, the only way that you are going to run richer is if you have more fuel being added with proportionately less air. The throttlebody doesn't send signals (other than the TPS) to the PCM. It doesn't have any airflow measureing capabilities like the MAF sensor does. It's just an airvalve.
Leaner where? At idle? Or low TPS settings? That makes sense because the TB will allow more air thru the TB at low throttle settings after it’s ported. The ECU will then account for that in open loop mode, when you get to WOT the tables will be skewed to add more fuel because of the lean low end condition. That and the fact that the motor is now seeing more air at WOT is good.
thats from him
(Here's one little hint: The air velocity going through the MAF will be the same at a given air volume. At a given power level the air volume is the same regardless of the opening of the TB (and therefore regardless of the velocity of the air at the point where it goes through the TB. The air can go faster through the TB without effecting the velocity through the MAF so long as the volume of the air stays the same.
Also..."The ECU will then account for that in open loop mode" I think you meant to say in closed loop mode.
Ok, more later.
Keep in mind I am STRICTLY talking about steady state constant conditions such as driving at 65 mph under a constant load. At WOT the air is accelerating through the TB and that falls under a different set of rules.
Colonel
I used throttle in a generic sense.
From webster
"To compress the throat of; to choke; to strangle."
an air filter does that, a MAF housing does that (don't mess with a MAF housing though unless you can dial it in with LS1 Edit, you throw off the transfer function), the shape of the TB can also have an affect which is why you port it & shape it.
Ok so how does this improve fuel economy? Hint: pay attention to the velocity profile of the airflow and the way flows AROUND the TB blade. Pay attention to whats happening within the control volume. Conditions are far from ideal and friction comes into play hence the velocity profile.
Kinda hard to explain with words but I tell you what. I have access to Finite Element Analysis (FEA) software and CAD software as well. I am a bit rusty with both but this would be a great opportunity to get cranking again. I'll prove my point with colorful pictures
stay tuned........................
Ok, more later.
that was the guy at bauer that sent that to me so its just what i copied out of the email.....
the basic point i was trying to make was the MAF should have some kind of change wouldnt it? if the throttle body is bigger the same amount of air would flow through just at a different velocity, but yes that is after the MAF so the TB doesnt sense the velocity of air like you said....so i started to think, and i got nothing really lol just still KINDA think it would effect the MAF numbers SLIGHTLY but like i said this is what the guy from bauer sent in an email so he might have misinformed me. but please clear this up for me cause i would like to know, im in no way trying to prove anything just trying to learn some more stuff, just got into the computer stuff about 6 months ago and im still learning, between that and a full class load, its too much sometimes lol
Don't take this the wrong way. It's good to know what a product is going to do for you before you make the purchase but something simple is turning into rocket science.This product isn't going to help you knock a few tenths off your 1/4 time or gain a few MPH at the track. It's a $50. piece of plastic that is supposed to give you a few horsepower up top and more throttle response/power down low. I've posted what I've seen and I believe there were a few posts in the other thread.
VaraRam's website can be seen at - http://www.vararam.com . They have info and their phone number on there.
Tom
lol
lolThat's ok
Here is something that was posted on one of the truck boards recently. I know, it's gas mileage related but this is his feedback -
okay, just to give you an update on what this thing actually does... all i really got out of it was 1.5MPG which is good enough for me.
This is pretty much what alot of people would buy it for. Some trucks are lucky to see 8 MPG so anything helps. Most of the VR Stacks that we sell goto truck owners.
Tom
www.tbyrnemotorsports.com
4 weeks of running, .8 MPG solidly. Could never get over 20.8ish, now 21 with room to spare. You wont notice the Vararam on WOT bursts, where it really shows a presence is holding speed and or light tipins of the throttle. Lot less pedal effort in both cases.
