Poly Motor Mount
Old Aug 4, 2009 | 11:08 PM
the_merv's Avatar
Veteran: Air Force
Default Poly Motor Mount
I bought a set of LS1 Motor Mounts and one was a stock and the other a POLY Mount.
Does anyone sell a single POLY Mount so I can replace the stock one with it?
Edit: I got one, I have two now.
Old Aug 4, 2009 | 11:32 PM
00pooterSS's Avatar
return it and buy a normal poly mm kit. That sounds strange like something is wrong there.
Old Aug 5, 2009 | 09:12 AM
the_merv's Avatar
Veteran: Air Force
K..I type it wrong.
I bought a set of complete upper and lower LS1 Motor Mounts..basically what bolt to the Block and to the K-Member. Installed in only one of the Clamshells was a Poly Mount, the other was still stock.
Someone half-assed it and that is why I need the extra.
Old Aug 6, 2009 | 05:24 PM
00pooterSS's Avatar
that sucks, sorry I dont know if anyone does, I highly doubt they do, but good thing is they arent terribly expensive for a set. Doubt you could wear out poly ones so used ones would be cool if you found any.
