Opinions wanted on Mufflex 4" Catback
That's MISTER MODERATOR
I had the Mufflex 4 inch system with the Spintech muffler installed by them on my ‘94 in their shop.
First, they mangled my Kooks Y pipe and used some sort of huge coupling. It was pretty ugly.
Second, don’t be taken by them saying 4 inch pipes will fit. It didn’t. They even wedged a rubber block between the top of the pipe and the body. It fell out.
Third, the hangers they used (they make them up with steel rods) were barely in the rubbers on the body. They pulled out and the whole thing hung down on the rear. I had to re-work their hangers.
Forth, it hit everything. Big dents from the rear universal joint and from the rear’s axle tube.
Fifth, I didn’t care for the frequency and it’s drone on the highway. From inside the car, it was terrible. I like a loud exhaust but this sounded plain bad to me.
You may not gain very much with the 4 inch system unless you have some pretty big cubes. Some back pressure can be a good thing.
I for one will advise to go with a 3.5 inch system. If you think you need more, you should be looking at a true dual system.
For my new car, I’ll be going to the 3.5 inch system from Stainless Works. When I have the bucks for it and the K-frame, Kooks headers and Y-pipe, that is.
i do have big inch high hp car with 4in mufflex/mag muffler.i installed system my self just takes time to get right.mine fits great and hits no where.spintec muffler really sucks + is heavy as hell.
tals7, maybe I shoulda had you do my install. Perhaps the other muffler choices are better sounding (or worse...).
To the OP: Do you really need a 4 inch system? Buyer beware, you can do the install better yourself than the company that makes/sells/installs the system.
Mufflex installed your exhaust? Why wouldnt they have used one of their kits instead of fabbing it up right there? The pipe going over your axle clearly shows that they made it on the spot, and didn't use their pre made pipes. I'd be pissed too! Was there something different about your car that made it so they couldnt use their kit?
They said that was the kit. It had to be put in sectioned like that. They said they all looked like that.
I didn't surprise them, I had made an appointment days earlier. It was a long drive and I didn't want to just drop in for the work. I dedicated a day for the drive there, the time in their shop (about 2 hours) and the drive home.
They suck. I wouldn't reccommend anybody to use their stuff. If you have and had good experiances, good for you, I'd say you were lucky. Their website makes them look pretty good. It's a small shop that looks to do general repairs. I wasn't impressed.
I saw the Stainless Works 3.5 system on a car, it looked way better & more precise. It sounded good too.
Also I thought all you guys were being over dramatic about the Spintech muffler weight but I WAS WRONG THAT SUCKER IS HEAVY!!
#34
Grifter's system looks all made up from sections with rod hangers like mine was.
SmokedOutZ28's system looks like the real deal pre-bent pipes with proper hangers.
I'm certain that if my system had the pre-bent pipes and good hangers, it woulda been better.
Regardless, I feel I bought an inferior product with poor craftsmanship and won't recommend them to anybody. The rubber bumper they used between the pipe and body showed me they did a lousy un-caring job. Freekin system fell off the hangers, how would you feel if this happened to you? The pics say it all. Screw them!
#36
I love the system, they were great to work with and I feel the quality of the product is top notch.
#37
kind of bringing this one back, but has anybody had problems with heavy resonance on the highway? my 4 inch mufflex drones BAD on the highway.. sounds ******* sick at idle with my cam, and at WOT. if i could just find a way to stop the resonance at cruising speed, id be totally happy. any ideas? i cant figure out which muffler i have, its black and a bullet style 4''. spintec maybe?
#39
#40
parallel behind the back axle dumping out the driver rear. i like the loudness, its just the resonance.. any ideas on what to add to stop that without making it quiet?
