Meziere WP319 question
Old Aug 11, 2009 | 09:41 AM
OutToWinPAHC's Avatar
Default Meziere WP319 question
I just ordered one of these guys. Not sure, I read the PDF file on the website, but what T-Stat do I use? I have a LS1/LS6 style waterpump and a 160T-stat which is a month old. Is that compatible with this, or does the Meziere pump use LS2/3 T-Stat?
Old Aug 11, 2009 | 09:47 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
It will come with a 180 thermostat. It's small block style I believe, not LS at all. It relocates it to the inlet instead of the outlet.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 11, 2009 | 04:45 PM
teke184's Avatar
correct they ship them with 180 stats....you still have to drill the bypass holes in it though.
i say see how it runs with the 180...you my be pleased with the temp the car runs at.
and a standard SBC 160deg stat can be bought at any parts store for about $10.
i have a 160 in my Mez setup, with the holes drilled. and the car still runs right around 172-175 with a fan switch turned on HI.
so i figure i may be a little above that under highway conditions....which is a good temp for me.
Old Aug 11, 2009 | 04:51 PM
Nice, I have been running warm so I ordered the pump, pull the headers for ceramic coating then wrapping, as well as other things as well.
When you say bypass hoes do you mean for the heater core, or just the holes in the T stat drilled out.
Old Aug 13, 2009 | 09:46 PM
teke184's Avatar
holes in the stat to allow some water flow to prevent pump burnout
Old Aug 14, 2009 | 09:05 PM
bowman2005's Avatar
Do you really pick up like 5rwhp?
Old Aug 14, 2009 | 11:17 PM
No idea, its less rotational force, but I am going for the increased flowrate to lower temps.
Old Aug 15, 2009 | 08:10 AM
teke184's Avatar
electric pumps are proven 10hp on the LT1 cars....
so i can easily see it with the LS1
