coolant pipe and plugs necessary for intake swap?
Old Aug 15, 2009 | 12:19 PM
blk99sleekbeak's Avatar
Default coolant pipe and plugs necessary for intake swap?
I was going to put my ls6 intake on today and while reading on ls1howto it said you will need new coolant pipes and plugs.I ground the fins off the bottom of the ls6 intake because i was under the impression that if you did this then the new pipes werent necessary.Can someone clarify for me?
Old Aug 15, 2009 | 12:37 PM
99Bluz28's Avatar
That's what I did except only where the coolant pipes go under the intake.
Your good to go!
Old Aug 15, 2009 | 12:41 PM
Thanks alot.Going to get started
Old Aug 15, 2009 | 03:16 PM
venom99's Avatar
did you guys just block it off
Old Aug 15, 2009 | 05:33 PM
Z28LS1camaroguy's Avatar
i didnt grind anything and it clears just fine took it off recently to fix a vaccum leak and no problems at all with sealing with the coolant lines.
Old Aug 16, 2009 | 04:56 PM
I was also going to use the fuel rails and injectors that were on the intake.its off an 02 z28.if im not mistaken it has 26lb injectors.how crappy will it drive with those?i just ordered some weld in LCA relocation brackets and im going to have to drive it a couple of miles to a friends house to use his mig welder
