LS1 GTO choking on w.o.t.
#41
As said before, try to get the car hooked up to a scan tool and take a look at the fuel trims and maybe even the fuel injector pulse width for each cylinder. Also, if you can get a long enough connection, try hooking up a fuel pressure gauge so that you can see it and drive the vehicle at the same time and see if the pressure stays up at WOT. Might even try running some injector cleaner through the car. If it fixes the problem great, if not you still end up with clean injectors lol.
So,do you think that I should try the injector cleaner or just do the flow test? I have had so many mixed opinions on injector cleaner it is hard to decide what is right?? Also what kin of pressure should I be getting at W.O.T. compared to idle (which was about 60 psi when the shop checked it)?
#42
yeah! This is which way I am leaning with the problem now. I was thinking I might try to get all the injectors flow tested and cleaned like a couple guys suggested. The shop I took it to said something about the injector bandwith being different on the bank two making it lean out...."DUH!!"....but didn't offer any reason for this or how I should try to fix it .Other than saying "somthing is wrong with the computer" Which I think is a cop-out statement that every mechanic sais when he can't figure something out.
#45
#46
Try spraying some carb cleaner or similar around the edge of the intake and see if it runs rough. I had to replace the intake gasket(s) on my TA because it was throwing lean code and would almost fall on it's face at WOT. Took a while to figure out though, because it was leaking on the INSIDE of the gasket so spraying around the intake didn't change anything as it was still sealing good there.
#47
#49
Not sure, but the fuel pump may not be able to keep the fuel pressure high enough as the volume being pumped to maintain pressure would be higher in the larger line. Just throwing that out there as food for thought
#50
I was thinking along the lines of the "water hose" analogy. If you had two water hoses...one larger than the other.....both have the same spray nozzle and the same water pressure.....the larger one will flow slower with less deliverable pressure than the smaller one when they are both held wide open. However they would work the same if the nozzle was held 1/4 open. you follow what Im thinking??
#51
I went back and checked the specs of my fuel pump (#sum-G3138) and it said the pump has a 45GPH free flow and a 85-PSI max fuel pressure. So, I would think that it would have enough pressure to keep up the 60-PSI I read on idle. even on W.O.T.??
#52
#53
Well it looks like we are leaning back to the possibility of vacume leak. So, my friend suggested we take the intake back off and re-do all the intake o-rings. If for nothing else then to eliminate the possibility. We are also going to buy four new injectors just to see if anything changes. I'll let you know what happens.
#54
#55
I follow the thinking, but it happens to be wrong. If you have two lines (the 3/8 and the smaller 1/4) using the same fuel pump and the same ending nozzle - the larger line will deliver more fuel, always. This is because the pump will pressure both lines to the same pressure and the larger line will contain more "stored" volume than the smaller line. Additionally, the volumetric advantage of the larger line becomes more dramatic the longer the distance involved.
