Has anyone modified stock valve covers?
Old Aug 24, 2009 | 07:44 PM
omc8's Avatar
Default Has anyone modified stock valve covers?
Has anyone modified stock valve covers ,to look more like the competition style.Thats without the provisions to bolt the coil brackets to the covers.I was wondering if they could be cut off and then ground down flush and still have a good result.
Old Sep 30, 2009 | 01:37 PM
omc8's Avatar
No one ,someone has to have tried to do this!
Old Sep 30, 2009 | 06:42 PM
ShortChevy's Avatar
I have thought about it and I am sure you could. I just didn't want to defeat the point of the coil near plug setup we have.
Old Sep 30, 2009 | 07:20 PM
fatdave's Avatar
I have I will try to find a pic
Old Sep 30, 2009 | 07:21 PM
fatdave's Avatar
Here ya go[IMG][/IMG]
Old Sep 30, 2009 | 07:36 PM
TJ's Avatar
TJ
i have seen other images as well.
all it takes is a couple cutoff wheels and a sanding wheel.
Old Sep 30, 2009 | 08:42 PM
Spd-Kilz's Avatar
http://www.planetlsx.com/vehicles/Sh...d_Firebird/102
Old Oct 1, 2009 | 04:57 PM
omc8's Avatar
Your the man Fatdave thanks for your pic, thats the drivers side cover?Did you have them powder coated or is that high temp paint?Any more pics would be great.
Old Oct 1, 2009 | 08:00 PM
fatdave's Avatar
yea thats the driver side cover. I milled off the coil bosses then tig welded in the bottom of the bolt holes, sanded then paint and clear. The paint is actually duplicolor wheel paint that matches what I have on my rims. Getting the rims powder coated black so I will be doing something different with the valve covers I will look for more pics
Old Oct 1, 2009 | 09:39 PM
LargeOrangeFont's Avatar
cool!
Old Oct 3, 2009 | 04:31 PM
omc8's Avatar
Thanks for the more detailed info.Thats what I thought ,that there would be a small void area, that once the boss is cut down and ground flush.I'm a good welder but don't have access to a tig so I guess mine may have to wait til I find someone to weld them cheap.I believe mine have a total of 15 bosses, do they all require filling? A couple are a little taller and wider than the rest.And what brand of clear did you use ?I was afraid that it may yellow or haze the clear coat do to heat, doesn't seem to be a problem on yours.They look great!
Old Oct 4, 2009 | 12:44 PM
fatdave's Avatar
you can also use some liquid metal from loctite to fill in the little holes that are left. I used Duplicolor wheel coating clear on the covers. They are holding up great so far.
