ok, radiator question here
Old Aug 30, 2009 | 09:51 PM
JAX04's Avatar
Default ok, radiator question here
Im in need of a smaller yet efficient radiator, but i have no idea how to size a radiator properly, my first guess would be to find out what the volume of my stocker one is and find one that carries the same volume but in a shorter and and not as wide "frame". is this good thinking or am i an idiot?
Old Aug 31, 2009 | 07:43 AM
99blancoSS's Avatar
Well your looking something that is physically impossible I think. Performance radiator use a double row of tubes which makes them thicker. Your looking to go thinner.
Call Ron Davis Racing 623-877-5000 and tell them what your looking to do. They might be able to make something to accommodate but it will be a special order and not cheap
Old Aug 31, 2009 | 12:39 PM
JAX04's Avatar
im sorry, i can see how that was misleading, using LENGTHxWIDTHxDEPTH, i need one that is shorter in both length and width, i can use one wider. but it needs to be shorter in both length and width. so would finding one that is shorter in both ways but carries the same volume due to the thickness work?
Old Aug 31, 2009 | 02:20 PM
99blancoSS's Avatar
Yep, give me the dimensions and I'll match one up.
Old Sep 2, 2009 | 02:12 PM
JAX04's Avatar
its a factory raditor in my 2004 gto. 5.7 litre. but will soon be turbo charged. so what ever it takes i guess. and ill measure one up tonight and see what i need. also. when it comes to transmission coolers, how do i know how big to go then, obviously, the bigger the better, but just wondering.
Old Sep 2, 2009 | 03:23 PM
jimmyblue's Avatar
Moderator
I don't know what the GTOs have, but the F-body radiator is too
small (skinny core) for the motor in my book. Putting an intercooler
in front of it will only hurt more. Ditto the trans cooler.
