Ported LS1 TB damaged in shipping-need help
Theres still newspaper stuck in the crack from impact.
id be hesitant to use it, im sure there are ways to though, maybe cut/break the piece off and smooth it out
but ya im like you. hesitant to use it. either way im still fileing a claim with UPS
I would try sanding it down, but since you've filed a claim with ups, don't touch it until they can evaluate it-- if you "fix" the damage, they will be less likely to reimburse you IMO.
They basically said I'm fucked and to keep it.
He said if I went through with the claim, they have to take the WHOLE package (so the throttle body and the intake since they were shipped together). They inspect it and if they say "yeah we damaged it, its our fault" then they send the WHOLE package back to the shipper and then he gets the money. I would have NOTHING!
And they said based on the looks of the packaging they wouldn't pay anything.
1. break off the damaged piece and build up some JB Weld to make a replacement. I'd use a piece of masking tape on the outside of the bell to hold the shape, then put down a layer or two of JB Weld to fill to the inside edge of the bell, followed by a little filing and sanding.
2. see if you can bend the cracked piece back into place without breaking it off, then use the JB Weld to hold it in place, with a little skin on the outside to help.
