Throwing code P0171 System too lean, bank 1
Old Sep 5, 2009 | 01:50 PM
!!!FAST!!!'s Avatar
Default Throwing code P0171 System too lean, bank 1
What should I check on this? 2000 T/A WS6. Just added BBK SSI Intake, 85 mm throttle body, SLP CAI, smooth bellows, lid, K&N air filter cleaned, Magna Flow cat back. While driving it popped the code. Also noticed that when warmed up and driving the rpms would not drop for a few seconds when I engaged the clutch or let off. If I let the tranny slow it down it would eventually hit a position that dragged the rpms to normal.
Old Sep 5, 2009 | 03:10 PM
bambaboy's Avatar
congratulations, you have a vacuum leak
Old Sep 5, 2009 | 07:13 PM
WARP211's Avatar
+1 most likely its a vaccum leak did you check the brake booster hose?? I would check all the hoses and if you hear a loud "hissing noise" its a vaccum leak. don't mistake the hissing noise as regular intake noise they can sound similar.
Old Sep 5, 2009 | 07:55 PM
99huggerorangeZ's Avatar
check your intake gasket, i know the 5.3/6.0 lsx motors are notorious for bad intake gaskets.
