What is the size of a stock crank bolt?
A standard 3 jaw puller will take the stock pulley off, and a standard three bolt harmonic balancer or "pulley" puller will take off the ASP or simular pulley.
time to
the asp pulley. I run a longer bolt due to my ATI hub have an inch longer shoulder inside the hub.
You can get a bolt of the same alloy from Mcmaster Carr for about $3 plus shipping, but you'll need to find a large diameter hardened washer if you want to use it as the crank bolt all the time.
They have them up to 140mm length
Thanks again Harlan and 2001Pewter
