whats the thread pitch on cylinder head face
Old 09-15-2009, 01:34 PM
SVC707's Avatar
Default whats the thread pitch on cylinder head face
what is the thread pitch of the threaded holes on the front face of the cylinder heads... i cant seem to find one that fits without going to the store and buying one of each
Old 09-15-2009, 01:49 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
M10x1.5
Old 09-15-2009, 03:26 PM
SVC707's Avatar
is that the lower, or upper... i need the upper towards the valve cover holes
thanks
steve
Old 09-15-2009, 10:18 PM
01ssreda4's Avatar
There are a bunch of random bolts in the motor that fit the cyl head holes. I was messing around the other day and found a bunch of misc engine bolts that fit those hoes. Its like everything is the same size on the engine
Old 09-15-2009, 10:29 PM
S10xGN's Avatar
3/8-16 bolts will fit, but be aware they will strip the threads in the head when tightened!
Old 09-16-2009, 10:02 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
3/8 is def smaller than 10mm....why would you even suggest a standard bolt in a metric threaded hole?
Old 09-16-2009, 12:19 PM
S10xGN's Avatar
Sigh... I wish people would actually read posts. I certainly did NOT suggest it, I merely stated "they will strip". This was posted in hopes of PREVENTING some dumba$$ from accidentally trying to use a 3/8"-16 bolt (believe me, there are pleny of them out there who have already done this). In your capacity, you of all people should know...
Old 09-16-2009, 12:24 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Maybe you should not have even brought it up in the first place? Just because you want to be a wise guy doesnt mean the rest of us do. If you do not suggest it, then why would they try it? Maybe it should have read do not use 3/8?
that is why i said why even suggest it? he appears to be learned enough to understand the LS engine is metric, so its not nice to insult said intelligence with an answer like you stated
Old 09-16-2009, 12:41 PM
S10xGN's Avatar
John: I'm not gonna spar with you. You've been here long enough to see plenty of "stripped thread" stories, I'm just trying to save someone some grief. You're too good a guy to get involved in a pointless pi$$ing match.
To anyone else who cares: Use only metric fasteners on the LS motors! In all of the holes! Hope this saves someone some stripped threads...
Old 09-16-2009, 12:58 PM
SVC707's Avatar
all this drama... thanks though i found the belt tensioner bolt is the same so ill buy a shorter one of that.
Old 09-16-2009, 01:43 PM
01ssreda4's Avatar
Ha ha told ya
