Radiator fans affecting track times !!
ones he tried to make his fans working at full speed before the run using hp tuner his time dropped to 11.3 in the same day same weather
any body tried this before ?
we didn't expect this drop in performance due to amperage drop caused by fans
wonder what times you could run with them off doing a pass ?
If the alt is full fielded, and putting out 140A, @ 13.5 volts, the wattage is 1890.[volts x amps= watts] Converting that to HP= [1890x.001341]=2.53 HP. And, that 2.53 is not the added HP loss, as there's already a load of some amt on the system.
That's not likely to be the cause of the loss in performance.
Other causes:
Lower volts to the ign.?
Low volts to the fuel pump.?
PCM incapable of sufficient inj voltage correction?
