Started my Header install today, Ran into a problem
The bolt in the rear is sticking out. So I should be able to get that one. I was planning on gentle heating the head with a propane torch and the blasting the bolt with freeze spray.
The one up front I 'm going to have to drill and easy out that one.\
Anyone got better Ideas??
Ed
The one that has about a 1/4" sticking out is the one all the way to the rear.
The one that is about 1/8 inside the head is the one all the way to the front.
Ed
Find two nuts with the same type of thread but narrow enough so they both fit.
Then tighten the nuts up to each other, and put a wrench on the nut closer to the head and you might get it.
The one thats 1.8 inside.. Im not sure what you can do....
This is a delicate operation, don't want to mess up your heads if the drill slips or is on even the slightest angle.
I would remove the head and do it on the bench.
Not the answer you were looking for.
1. I have Mamo ported AFR 205's sitting 5 feet from where I'm typing. I also have a the AFR 224/228 114 LSA cam brand new (which I need to sell) and crane lifters, Yella Terra Rockers etc.etc..
2. Eric Koenig at HKE is 3/4 finished with my LS3 416 short block (which has a PAT G + Engine Power Systems) spec'd cam .
3. My plan was to install the headers and exhaust with Wideband, then install then tunable parts injectors, intake and fuel pump etc. then tune with my EFI live.
4. Then drop the motor and swap intake, headers and put then new one up and flash the computer with new with a different VE table. That should be a good starting place to tune.
So all of this complicaties my situation.
ED
I would have very little confidence in my tune data.
This one isn't going to be so easy!
Or if I had to drive the car, I would just install the headers without that bolt and skip the tune for the time being.
But that's me, and we're talking about you.
I made this jig from the gasket, I wanted something to guide the drill bit and stop it from wandering into the head.
Then bolted it on and hit the drill for a second, then removed the jig and verified the location.
Mirror check
I then bolted it back on and drilled an 1/8 inch hole. I then used a brand new extractor from Sears. It slipped after I looked at it the extractor was all tore up. Of course its suppose to be high carbon steel. It said made in China on it, imagine that! I then drilled it to 3/16 and used the other extractor and success!
The good news is the extractor did not penetrate the sides so the threads have not been damaged.
