Header Hell (funny) cont. of ran into a little problem thread
Old Sep 21, 2009 | 02:12 PM
-Q-'s Avatar
-Q-
God almighty. And I have a set of headers, catted Y, and cat-back sitting in my garage waiting to go in...should not have clicked this thread...
Old Sep 21, 2009 | 08:55 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I'm thinking that with all the other advantages to having a tubular K-Frame, this header install makes it's investment all that much more worth it.
I would put "tubular K-Frame installation" on my "must do" list.
I'm planning on doing headers, K-Frame, Y-Pipe and cat-back in one shot. I still have the tubular upper & lower control arms and 13 inch SSBC brakes from the '94 which is finally being parted out.
Old Sep 21, 2009 | 10:22 PM
HavATampa's Avatar
No way I would have gone through all that trouble to get a set of crappy fitting headers to fit. Even if I got those headers for free, I wouldn't have done all that cutting and welding. How well are the collectors lining up? Are they close to floorpan? Do they even point toward the rear of the car?
Old Sep 22, 2009 | 10:41 AM
blk99sleekbeak's Avatar
Wow!that is some header hell.i did pacesetters a couple of weeks ago and did not have to grind,cut,weld,or beat anything.only thing i had to do was unbolt the steering shaft and move it back about a quarter inch
Old Sep 22, 2009 | 12:02 PM
99Hawk6spd's Avatar
Originally Posted by BRD-PREY
Hindsight is also 20/20, remember I was working by myself and it started out looking like a small cut here and a small grind there but hours later and much frustration they are in.
Besides Once I made one cut I might as well finish. I'm sure I was more **** than necessary but thats me.
Thanks for all the support, mentally that is.
PLEASE DO NOT CONSIDER THIS QTP's FAULT. THEY HAVE A GREAT PRODUCT!
Well FYI, I bought a used set of QTP's with the QTP badge, and my floorboard doesn't look quite as bad as yours, but I was under my car with a grinder the same as you. I would have had to cut my k-member except the holes for the header bolts are large enough I could jack on the back of the headers, and tighten them so it wouldn't hit my k-member. Although I think they still are contacting something when I corner, they are clearing for the most part now. I've heard if you do motor mounts when you're doing the headers, it can eliminate clearance issues. I did not replace mine, and should have.
On the other hand, although they were a bitch to install, my 99 Firehawk with 123k miles and an M6 made 340rwhp, and 350rwtq with just an LS6 intake and QTP 1 3/4" LT's. Dyno graph's linked below:
2 years ago unmodded vs now with LS6 and QTP:
http://werkdcars.com/dyno/garydyno2.jpg
tuned vs untuned:
http://werkdcars.com/dyno/garydyno1.jpg
I've been told that QTP outsourced their header manufacturing and that is when they started to not fit as well. I'm pretty happy with my numbers, but my fitment has been a bitch.
-Gary
Old Sep 22, 2009 | 12:25 PM
deadhorse66's Avatar
Only install I've ever done that was quite that bad was long tubes on a 67 Ford Fairlane, and I can feel your pain. Makes you want to run manifolds. Sorry it took so much dude!
Old Sep 22, 2009 | 03:02 PM
TORCHD 02 TA's Avatar
sory for your luck. I put my QTPs on in 2006 w/o a single problem. Jsut had the notch the k member ever so slightly..
Good Luck
Old Sep 22, 2009 | 03:21 PM
Jwright41's Avatar
Wow, that is crazy!! Guess that is why Im going to have someone else put mine in, hahaha!! Pay them for my pain
