Intake Bolt hole obstruction. How to clean "cleanly"?
After mounting my brand used AFR 205's tonight, I go to put my intake on, and one of the bolts will only go into the head about half way. I get the ol' bore light out, and it reveals some fawkered up threads on down the hole. I do a little investigating, and find that these holes dump right into the oil passage.
What can I do to clean the hole without dropping debris into my oil? I REALLY don't want to take my heads off. (new ARP bolts, new cometic gaskets-might as well be made of gold!)
I thought about the idea of a tap, but I don't think my engine would like metal shavings. Let me know what you think would be the best alternative here.
Get the correct tap and some medium bodied (light textured, a soft/sticky kind) grease and coat the tap flutes with it. The chips will stick to the grease in the flutes.
Hopefully it will contain all the debris.
