short O2 sensors??
Old Dec 2, 2003 | 11:46 AM
Deeavi's Avatar
Default short O2 sensors??
I just installed a set of Hooker Long Tube headers on my '98 Z-28. The drivers side O2 sensor is rubbing on the frame. Does anyone know of shorter O2 sensors for tight areas!?!
Old Dec 3, 2003 | 07:55 PM
WILWAXU's Avatar
Hmm,, the MAC's had this problem for a while. The O2 bung was welded in the wrong place.
Old Dec 4, 2003 | 09:00 PM
Deeavi's Avatar
Yeah, The Sensor wire is rubbing right at the end of the sensor, but just barely. If I take the fuel line heat sheild off, it will clear. I am going to drive it for awhile and see how it goes! Since I put Simulators in for the back two sensors, I have two extra sensors, if I need them! Also, the Y-Pipe is bumping on the underside side from the torque when I get down on the gas. I see that some other people have had that problem as well. I am gonna try and correct that this weekend.
Old Dec 5, 2003 | 08:10 AM
Deeavi's Avatar
I just emailed Hooker and asked them about the O2 sensors touching!?! They said they are aware of the wires touching and that shoudn't be a problem! As far as the Y-Pipe bumping, they said check the motor mount and recheck the installation of the pipe. So I guess that is what I will do!
Old Dec 5, 2003 | 09:24 PM
WILWAXU's Avatar
I would try to "modify" the heat shield for more clearence.
Old Dec 5, 2003 | 11:27 PM
Chris99WS6PWTMET's Avatar
They have a flaw in their set up and they say that it "shouldnt be a problem." That crap pisses me off. They should get off their lazy a$$es and fix the defect during manufacture. I installed a set on my buddys car last year and it was screwed up the same way back then. Gotta love that Hooker quality control!!
We re-routed some lines a little further outward and "massaged" the shield until it cleared. Just like WILWAXU said. Not hard to do but still a pain after paying that much cash.
