ls6 intake
Old Oct 5, 2009 | 08:00 PM
99LS1Bird's Avatar
Default ls6 intake
I put a ls6 manifold on my car today and there is a pretty decent sucking sound coming from the intake lid. also when i let off the gas crusing down the road after about 10 seconds it starts to surge as if i was tapping the throttle. any ideas?
Old Oct 5, 2009 | 08:08 PM
senicalj4579's Avatar
sounds like a air leak hmmm
Old Oct 5, 2009 | 08:13 PM
99LS1Bird's Avatar
it quits if i unclamp the lid and pick it up away from the filter the intake is bolted down good and tight i have the bottom of my air box lid cut out is the only think i can think of
Old Oct 5, 2009 | 08:33 PM
its not throwing a code or anything huh?
Old Oct 5, 2009 | 08:46 PM
kdick91's Avatar
If it stops when you life the lid up, you may have a vacuum leak where the bellow connects the MAF and TB. Just make sure it is connected well, your best shot is to get carb cleaner and spray around and see where it makes the RPMs jump. That's be the source of your vacuum leak, but it is definitely a vacuum leak. Not a big deal, usually an easy fix. Did you use all new gaskets?
