ses light is blinking on and off?
Old Oct 9, 2009 | 11:41 AM
frazierboy98's Avatar
If ur getting new 02s get the rears for I believe its an 02 vette some1 correct me if im wrong they are longer and you will not need any extentions.02 sensors will cause a miss but will not make the ses light flash at any point the light will just stay on till you get it fixed.Im thinking valve spring or as stated above me rocker arm or something of the sort.Plugs also will not show a flashing light b/c thats secondary ignition.I worked at a shop for quite a while and could be wrong as no1s perfect.Just check your plugs for wetness that gives you an idea as to which cylinder to look at first.
Old Oct 10, 2009 | 02:11 PM
BIG BILL 2000 Z's Avatar
alright guys i drove the car yesterday for the first time and the ses light is not blinking (just stays on) and the car does idle down a bit and is sluggish. all the plugs and wires are good and nothing is touching so all good there
