I need a muffler that is quiet and flows good ???
Old Oct 9, 2009 | 02:18 AM
lemons12's Avatar
Originally Posted by hitmanws6
lemons look at TORCHD02TA's setup, should give you some good ideas
Thanks for the tip!
Old Oct 9, 2009 | 03:57 AM
davidws6's Avatar
Default Magnaflow
I have a 4" straight through Magna Mufflex system and cruising it's a nice low tone.
WOT or accel, a lil raspy.
If the car had Cats, might tone it down a lil.
Old Oct 9, 2009 | 08:56 AM
slayer_taunu's Avatar
Originally Posted by hardcore4sure
Thats about the quitest of them all but does flow very well,just make sure the disc of silence is removed from the drivers side tail pipe.
disc of silence?!? how have i never heard about this
my car is waaaaay too quiet for me. how far in the pipe is it, and how do i get it out?
Old Oct 9, 2009 | 11:49 AM
kinglt-1's Avatar
Hooker Aerochamber!
Old Oct 9, 2009 | 04:28 PM
hardcore4sure's Avatar
It came on some Dual /Dual systems from the factory. It is a disc in the drivers side tail pipe that has a little hole in it to allow smoke to come out so it looks like both pipes flow but it essentially blocks the drivers tail pipe to reduce noise.If you have it, It is located at the muffler outlet where it mets the begining of the drivers side tailpipe. To test and see if you have one, have someone rev the engine while you are back there and feel if both pipes flow equally. Like I said before at idle you will see smoke from the tip but thats just for show, you need to rev and feel if the pressure is equal between tailpipes.The second test is measure the length of the tailpipe from the muffler the run a piece of wire or coat hanger down it and see if it stops. Unless somehow you can unclamp that tail pipe , you will have to take it to a muffler shop and have cut off the tailpipe ,remove the disc then weld the tailpipe back on. Good luck,hope you don't have it.
Old Oct 9, 2009 | 11:36 PM
MESS's Avatar
I like the hooker aerochamber muffler, but I was trying to keep this cheap as in just replacing the magnaflow muffler.
Old Oct 9, 2009 | 11:41 PM
lemons12's Avatar
How much do they run? New or used..
Old Oct 10, 2009 | 10:25 AM
01ssreda4's Avatar
Hookers are like 80 or 90 I believe.
Old Oct 10, 2009 | 05:34 PM
lemons12's Avatar
Wow, was expecting a lot more!
Old Oct 10, 2009 | 05:54 PM
z28camaross2's Avatar
magnaflow exhausts dont have this do they? because i noticed my driverside pipe is much quieter at idle and less is flowing from it
Old Oct 10, 2009 | 09:31 PM
RevGTO's Avatar
Pontiacerator
No, Magnaflow is a straight-through muffler with a kind of diverter inside. Under low flow conditions, most of the exhaust flows through the one pipe, and when flow increases, more is diverted to the other pipe.
Old Oct 10, 2009 | 09:50 PM
  #32
Paul57's Avatar
Here is a thread that may interest you...
https://ls1tech.com/forums/conversio...-mufflers.html
Old Oct 10, 2009 | 10:03 PM
  #33
oh ok thanks alot man didnt know haha. felt like a dumb *** asking but just had to lol
Old Oct 10, 2009 | 10:14 PM
  #34
SunsetOrangeZ's Avatar
2.5 in inlet, but it will achieve said goal...
http://www.summitracing.com/parts/WLK-17739/
Old Oct 11, 2009 | 01:45 AM
  #35
MESS's Avatar
outstanding, for $62 thats right up my alley
Old Oct 21, 2009 | 02:01 AM
  #36
MESS's Avatar
I ordered the Dynomax last week, I put it on today and so far so good! You can still tell it's a H/C car, just not as loud.
Old Oct 21, 2009 | 07:37 PM
  #37
Paul57's Avatar
Did you get the Super Turbo with offset in/out???
Old Oct 23, 2009 | 09:13 AM
  #38
MESS's Avatar
yes
Old Oct 23, 2009 | 10:44 AM
  #39
MonmouthCtyLS7's Avatar
Dynomax superturbo...little louder then stock....
Old Oct 23, 2009 | 02:22 PM
  #40
jbuhr's Avatar
I just ordered a Heartthrob cat back for 99 with longtubes and Y pipe. I will let you how it sounds. I know their HVS mufflers remove the drone and sound good.
