Slp Ram Air induction system
below, you have to modify the air box (cut away the
floor) and the radiator ducting panel. It may be 10HP
for a non-SS because of the reduced air temp but it
raised my IAT on an SS, over original by 5-10 degrees.
It gets hot sitting in traffic. I cut off most of mine and
made it draw more from the nose space and IATs are
now back to 2-3F above ambient. This way I have more
than doubled the inlet area for the airbox and it's a
shorter path than the SS roundabout hood duct.
In its retail form I think it's more solid construction,
but thermally inferior to the other options (FTRA /
SSRA), it also was an unacceptable radiator airflow
obstruction due to my trans cooler's location.
Used ones are a good deal since there's nothing you
can do to break it, and they usually go for about half
price if you're patient.
