All done with weiand swap
Old Oct 14, 2009 | 01:08 PM
Zaxz28's Avatar
Yah, I kept mine silver, to keep with the black and silver theme
Old Oct 14, 2009 | 02:07 PM
HVAC-Tech's Avatar
Are the stock manifold bolts and weiand bolts the same length? I bought a used weiand without bolts and wanted to make sure the stock bolts are fine to use. Also did you buy ls6 coolant lines or were you able to use your stock lines?
Old Oct 14, 2009 | 02:47 PM
Zaxz28's Avatar
No the stock bolts are not the same size they are much longer. I believe weiands are M6 x 1 x 90. But you can look it up under "weiand intake" on jegs for an ls1 and they include the instructions and in the instructions are all of the necessary bolts listed for you.
Old Oct 14, 2009 | 02:52 PM
Zaxz28's Avatar
I also had to use the ls6 lines, you can get them on ebay for a respectable price. The reg ls1 are too high, in fact I had to remove the green clips holding the knock sensor wires to the pipe "remove" not just snap off the green tabs.
Old Oct 14, 2009 | 03:53 PM
HVAC-Tech's Avatar
was there a reason why you didnt use the gaskets that came with the manifold? I bought a used manifold with no bolts and needs new gaskets.
Old Oct 14, 2009 | 05:53 PM
Zaxz28's Avatar
At first I did it because it was recommended, then I noticed the felpro gaskets have a notch cut out, If you have ever noticed that on an LS1 with the intake pulled off the head bolts (the round part), close to the valley pan, actually stick a little out. (See my other threads) this notch leaves a space where the head bolts is. So instead of the Weiand gasket drapping over the head bolts causing a bump for possible leakes, the felpro gasket "raises" the intake away from the headbolt and allows it to sit flush. I know it is confusing but I will see if I can dig up some pics.
Old Oct 14, 2009 | 06:01 PM
Zaxz28's Avatar
Here is the picture that shows the head bolts sticking out a little the Weiand lays over the bolts leaving a hump. The felpro gasket acts like a shim raising it to a slightley higher level, so no leaks!
Old Oct 14, 2009 | 06:14 PM
HVAC-Tech's Avatar
I see what your taking about. Thanks
Old Oct 14, 2009 | 09:15 PM
Gregorya24's Avatar
8 to 10 hours for a intake swap my oil pressure sending unit went bad on my car and i pulled my fast replace the oil pressure sending unit and put the fast intake back on torqued down in 30 mins
Old Oct 14, 2009 | 11:09 PM
Zaxz28's Avatar
Hey good for you, I am glad you could do it so fast, I must be missing something, I know a lot of people that can do it that fast, Honestly I just care that I did it right. Hopefully at some point I will be as fast as you are!
