ls6 intake?!?!?!
Old Dec 4, 2003 | 06:52 PM
Tripp's Avatar
Default ls6 intake?!?!?!
could anybody tell me as to what all it needs to come with or that i will need to install it right when it gets to my door?
Thanks
Tripp
Old Dec 4, 2003 | 07:33 PM
jrp's Avatar
jrp
SN95 Director
you'll need the intake and the new coolant tubes. thats it, should install in a few hours if its your first time. i can do mine in about 20-30 mines now
Old Dec 4, 2003 | 07:46 PM
WS6FirebirdTA00's Avatar
come do mine lol where can u get the lines from?
Old Dec 4, 2003 | 08:20 PM
Tripp's Avatar
yah, what WS6FirebirdTA00 said.
Old Dec 4, 2003 | 09:02 PM
01Z0H6's Avatar
Me too,,,,,
Old Dec 4, 2003 | 09:06 PM
it bet i could do it in 30 min, but i bet somethign would be messed up haha any secrets? haha
Old Dec 4, 2003 | 09:41 PM
muscleSS00's Avatar
Do Mine While Your At It If Ya Dont Mind!
Old Dec 4, 2003 | 10:01 PM
jrp's Avatar
jrp
SN95 Director
i've done mine so many times thats it becomes routine . you get faster as time goes on, as with doing anything on your engine.
and tripp: as far as the coolant tubes if you get the intake from a sponsor they should have the option to add the new coolant tubes to the package. i bought my intake off of ebay and the coolant tubes from gm parts direct. could probably be had cheaper from paceparts though
coolant tube p/n
- 1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788
Old Dec 4, 2003 | 11:14 PM
CAT3's Avatar
Restricted User
Big TIP;
Be careful removing and installing the intake. Move slow and careful, after taping up the rear 3 bolts on drvr side and rear 2 on pass side, slowly slide forward and up making sure the vacuum line for the brake booster does not get caught on the oil pressure sending unit. It breaks really easy. Then again, install, slowly slide it back and down keeping the lines and wires out of the way. Untape the bolts and tighten down.
Complete write up should be on install U,
Old Dec 4, 2003 | 11:21 PM
Tripp's Avatar
awsome guys! thanks for the words of advice and the part #s.
Tripp
Old Dec 4, 2003 | 11:23 PM
jrp's Avatar
jrp
SN95 Director
if you didnt know already JMX is the ****** man
http://www.ls1howto.com/index.php?article=5
Old Dec 5, 2003 | 01:20 PM
CAT3's Avatar
Restricted User
ditto
