Which Puller to Remove Powerbond Pulley?
Old Nov 3, 2009 | 01:33 PM
Titanws6's Avatar
Default Which Puller to Remove Powerbond Pulley?
Starting my H/C swap and need to find out which pulley puller to use on a Powerbond Pulley? Will the 3 ply spec'd for Chryslers work? I read on here I can rent one from Autozone. My mechanic installed it for me, now I need to get it off, thanks.
Old Nov 3, 2009 | 04:39 PM
01ssreda4's Avatar
I had a 3 bolt puller that was a generic from harbor freight for about 10-12 bucks. I got frustrated trying to use it so I hooked a generic 6 inch 3 jaw puller on the front lip and pulled it that way. The factory pulley doesnt have this lip so you cant do it. The powerbond has the threaded holes to use the bolt type puller.
Old Nov 3, 2009 | 08:42 PM
Titanws6's Avatar
Gotcha, so I need the 3 bolt type puller, not the 3 jaw puller, right? Thanks
Old Nov 4, 2009 | 07:36 PM
99Bluz28's Avatar
Correct!
Old Nov 4, 2009 | 09:13 PM
Titanws6's Avatar
Cool beans, now I have to cut my welded Y so I can drop the headers. The idea seemed good 2 years ago when I had it installed hahahaha
Old Nov 4, 2009 | 09:24 PM
MeentSS02's Avatar
Kleeborp the Moderator™
https://ls1tech.com/forums/generatio...ud-pulley.html
Hopefully that helps.
Old Nov 4, 2009 | 09:37 PM
Titanws6's Avatar
Thanks bro, instructions are printed, off to Autozone tomorrow to rent the pulley, let ya know how it goes.
Old Nov 6, 2009 | 01:13 PM
MeentSS02's Avatar
Any luck?
Old Nov 6, 2009 | 03:02 PM
Titanws6's Avatar
Not yet, I rented it yesterday, but spent the evening removing the exhaust/headers and heads. Probably wont' be able to get to it maybe saturday, sunday for sure. I am cleaning parts as I go too, and taking lots of pics....so far smooth sailing, knock on wood.
Old Nov 7, 2009 | 09:40 PM
Titanws6's Avatar
Originally Posted by MeentSS02
Any luck?
Good stuff, removal went nice and smooth, the crank bolt was a little tough, but other than that, so far so good.
Do I use the 3 jaw pulley to remove the crank sprocket? It didn't look like the Chrysler one would work?
Old Nov 7, 2009 | 11:45 PM
MeentSS02's Avatar
I think people have used those to remove the crank sprocket, but I've never done that myself so I'm not sure. Pretty sure the Chrysler one wouldn't work for it like you already suspect...
Old Nov 8, 2009 | 01:02 AM
Damian's Avatar
LSX Mechanic
Aside from the fact they're heavier than ASP's, this is yet another reason I do NOT like or use these pulleys. Pain in the *** to get off sometimes.
ASP "FTW" (Did I really just say that)
Old Nov 8, 2009 | 09:15 AM
Titanws6's Avatar
Well I guess Im just gonna rent the 3 jaw today and see what happens.
Dang block is hard as heck to clean, 10 yrs and 90k miles later, those graphite gaskets are on there pretty good.
