Misfire = Vibrations?, but no codes?
New L76 w/DOD junk removed and 6 speed, I have a slight vibe between 1700-2600 rpm, in neutral or going down the road. Shows random misfires with #5 and #8 getting considerably more. I swapped coil packs around, injectors swapped, 2 new sets of plugs, new wires, all wiring traced and checked, compression tests at 170 across all cyl., pulled valve covers, everything normal there, no vac. leaks or exhaust leaks.
I pulled the flywheel/clutch (all new stuff) and put it back together with a stock flexplate and get the same vibe in the same rpm range. Changed balanacer to a new ATI balancer, same results.
As far as the misfires go, you cant really feel them but when the motor smooths out above 2600 rpm, there are a lot more misfires showing.
This is driving me NUTS..........
