cheap O2 extensions?
Old Nov 22, 2009 | 06:14 AM
pheer's Avatar
Default cheap O2 extensions?
anyone know where to get a pair cheap?
i found a set on ebay for around 40$.... i don't feel that 2 lengths of wire with a plug on each end is worth even half that... anyone know a cheaper place/route?
Old Nov 22, 2009 | 09:23 AM
Gordo78's Avatar
Speedinc has 24" for 18.99 and 18" for 17.99. I don't think you can get much cheaper than that unless you make them.
Old Nov 22, 2009 | 12:58 PM
DarkJuggalo's Avatar
got mine from speed inc for around 20$ to my door.
Old Nov 22, 2009 | 01:05 PM
wtomlinson's Avatar
if you make them, make SURE you waterproof the splices. i learned that the hard way my first time.
Old Nov 22, 2009 | 01:28 PM
tnmotown's Avatar
I have some for you. $30 shipped for the pair. Check them out:
https://ls1tech.com/forums/lsx-parts...isc-parts.html
Old Nov 22, 2009 | 01:34 PM
black00ssFL's Avatar
The cheapest "extensions" would be just to repin the PCM. Put the rear o2 plugs in the front O2 pins. The rear O2 sensor plugs then become the front and are right there where the O2's plug into the longtubes.
