New Fast 78mm and 90mm?
Old Dec 13, 2003 | 07:52 AM
SOM WS6's Avatar
Default New Fast 78mm and 90mm?
My current setup has just bolt on's but come Spring I'm having a RMS 232 cam installed and later in the year a set of s2 heads. I have the LSX on order already with the 78mm opening. My question is would I benefit at all by going to a 90mm opening and TB at all? Or is the 78mm opening big enough. I'm wanting to be pushing between 540-570hp from my setup. I have a Jantzer TB right now.
Old Dec 16, 2003 | 07:36 PM
WILWAXU's Avatar
Hard to answer till a few cars get out there with this combo.
Old Dec 19, 2003 | 10:33 PM
tbyrne's Avatar
FAST only recommends the 90mm version for stroker motors. I'm sure some guys will try this on their modified stock displacement motor. It will be a little while before we get feedback on how this works for them.
Tom
Old Dec 19, 2003 | 11:28 PM
onebadz's Avatar
I dont think you will see much of a gain on a stock displacement motor, once you go ^ CI you will see a benefit from it. Keep with the 78mm for now. Good Luck
Wes
