TSP True Duals and Lowered Car? Will It Clear
agreed but as long as you know where the dips and potholes are you shouldn't have problems. other cars like corvettes are just as low and have terrible ground clearance. shouldn't be driving a sports car if you wanted clearance.
i installed mine on garage floor with the help of my buddy. Used jack and jack stands and each of us worked on each side. Try twisting some of the pieces that run off the headers and you can gain ground clearance that way. Just be patient it will work!!!Also the xpipe piece has a right and wroing way off installing it. I don't remember which way but you can definately tell once its installed which is correct way. Hope this helps!!
i have the tsp duals on my car. its tucked up really well. i had to re install in to tuck it up better but they r right, if you take ur time and do it right it will tuck very nice. even if it scraps a few speed bumps, its well worth it for the great sound you get from it.
Man, i went from a BS B&B triflo to the TSP td's and i could tell a descent difference in power, i have spent quite a bit of time tweaking the exhaust and it tucks up better that any Y-pipe setup ive ever ran, i can go over speed bumps with no problem but u have to drive like u have sense, of course the exhaust is metal , its not going to hurt anything if it gets a few scrapes on it anyways, most guys that go the TD route are more about racing not car shows....BTW my car has the heater hose mod w. stock rear springs and QA1's on the front, bout 3/4 drop in rear and 1in. drop in front
like i mentioned earlier in thread I didn't notice that much difference in power just sounded 100X better. If anything it gained a tad down low. I'm not concerned with a few scraps and what not on the exhaust car is not a show car just a nice weekend cruiser. and like the previous poster my ground clearance is also better than my ypipe setup was!!
