Edelbrock LT's Closeout Sales
#46
So they come in Stainless to? I didn't see no 65701
#53
well i mean.. pretty sure every collector is a merge haha.. maybe im wrong, but the non welded version is there high velocity merge...
the better one was cheaper, i ordered the high velocity, im sure any competent welder could weld them and it prlly wont be very expensive...
cant wait to install mine!
#54
id like to get these,do you have one with air/egr? and i want them bolt in and go,i dont want to weld anything! also whats the clearance on these my car is dropped about an inch or so?
does anyone got these with a lowered car?
#55
I don't think there is an issue with the header clearance, but I bet you'll be working on some speed bumps with the Y pipe (since you're lowered)... and your floor board if you don't do poly engine mounts (which I highly recommend doing while the exhaust is off the car).
#56
#60
the headers came in.
out of the box.
hardwear, gaskets, O2 extenders, all EGR-AIR bungs to weld on if needed.
collectors and pipe extentions.
collector.
header.
header with collector.
These are FULL custom headers. Everything is to be custom fitted for a perfect fit and finish.
out of the box.
collector.
header.
