75mm MAF to 92/92 FAST
Old Dec 6, 2009 | 05:05 PM
kamarobuddy's Avatar
Question 75mm MAF to 92/92 FAST
Tomorrow I am installing my FAST 92/92. The problem I have is connecting a stock size 75mm MAF to a giant 92mm Throttle body!!! what can I use to fit that mis matched 75mm maf to 92mm Throttle body?
I know what you thinking...buy a 92MM LID and larger MAF and solve my problem. Well hollidays are here and money is tight so I am currently going with the stock size LID and MAF.
what the heck can I buy to connect the stock size MAF to a FAST 92/92?
P.S. Will a Smooth bellow connect to a stock size maf and to a Fast 92 Throttle body or do I need a larger MAF for the smooth bellow and not as large Throttle body? AHHHH please help!
Old Dec 6, 2009 | 06:22 PM
come on people, were better than this... I would appreciate ANY help
Old Dec 6, 2009 | 06:34 PM
JeaneZ28's Avatar
Check this place out, they have silcone reducers.
http://www.siliconeintakes.com/index...69f93445561ded
Old Dec 6, 2009 | 06:54 PM
so exactly what size am I looking for for the 75mm to 92mm conversion
Old Dec 6, 2009 | 07:07 PM
PUNISHER TA's Avatar
3.5" to 3"
Old Dec 6, 2009 | 07:40 PM
JeaneZ28's Avatar
Originally Posted by PUNISHER TA
3.5" to 3"
are you sure about that? 92mm converts to 3.6" and thats I.D. not O.D.
OP go measure the O.D. of both then you'll know what size you need.
Old Dec 6, 2009 | 08:26 PM
Darkman's Avatar
I think you have to measure the actual OD of the hardware in question. For example, the OD of the 78mm throttle body used on an LS6 is the same as the OD of the 90mm throttle body used on an LS2. (I know this because I did a swamp and was able to use the same intake tube.)
Old Dec 6, 2009 | 09:31 PM
JeaneZ28's Avatar
Thanks MR. Obvious. j/k
Old Dec 6, 2009 | 10:44 PM
massls1guy's Avatar
The stock accordion style connector will fit over a 90mm TB with a little stretching. I'll bet it would stretch over the 92 as well to get you going anyway.
Old Dec 7, 2009 | 12:33 AM
navyblueSS's Avatar
The stock bellow will work. I am running the stock accordian style bellow on mine.
Old Dec 7, 2009 | 06:37 AM
teke184's Avatar
running stock bellow on my Fast 90.
took an extra set of hands the first time...but it fit
Old Dec 8, 2009 | 12:21 PM
Dewman's Avatar
Fernco 3.5'' to 4'' reducer. I would post a pic of mine but i cant get photobucket to work
Old Dec 8, 2009 | 01:26 PM
teke184's Avatar
if you really want:
probably the 4" to 3.5" is the best fit.
Old Dec 8, 2009 | 01:33 PM
JeaneZ28's Avatar
Originally Posted by teke184
if you really want:
those are expensive and would look funny on a car.
Old Dec 8, 2009 | 05:48 PM
teke184's Avatar
they're basically what the "smooth bellow" is from SLP.
and i think SLP sells them for $50
but whatever
Old Dec 8, 2009 | 05:51 PM
JeaneZ28's Avatar
but whatever
Well the SLP have an angle which is a plus but I bought one from the company below. Their cheap and work great, real flexible.
Old Dec 8, 2009 | 06:45 PM
Dewman's Avatar
$7.99 + tax from home depot
Old Dec 8, 2009 | 10:53 PM
transam69230's Avatar
^ Thats what I ran for months!
Old Apr 11, 2017 | 11:13 PM
FGax9's Avatar
does it run good like this?
Old Apr 12, 2017 | 03:19 PM
BrntWS6's Avatar
I know your trying to save but i paid $30 for a GM maf on ebay. Lid is another expense of course but just an fyi.
