ASP underdrive pulley or SLP underdrive pulley?
All pulleys will be similar and will reduce hp loss through the accessories by a few hp. Nothing huge and they all will be similar. Since they all yield "essentially" the same performance results, go with the one thats made the best and is the most reliable. I only did one because I was doing a cam, not because I wanted a few extra hp.
I just ordered summit's crank pulley from them. it was only 182.99. I mainly ordered it cause i needed it next day and it was the cheapest. Anyone heard anything bad from them? Also i need a part number for the goodyear gator back belt for a underdrive crank & alt. pulley.
#33
Did yours come with an (overdrive) alternator pulley also?? Like the one in this picture... http://www.summitracing.com/parts/SUM-C2520/ ??
#35
ummm...wheelie bars and a parachute???
On a little more serious note...not sure if that would require something a little more advanced like a Fluidampr or not.
#36
http://www.summitracing.com/parts/SUM-C2502/
bbut what you posted is only 7 dollars more lol but not the right pulley
#37
Abdullah,
they will both performe the same (NO BIGGY), why do u care about track numbers since we dont have it here ,
make sure u order the acc belt from the US, it was a PITA looking for one here.
good luck.
EDIT: I have a brand new 200amp alternator from Load Boss High Output Alternators, ill let it go for 80kd (it weights approximatle 20lbs).
good luck.
