FAST 92/92 or LS6
back to back dyno runs, same day, tuned for each...so the gain was from the intake.
and that was CAM ONLY!
so YES its worth it for the FAST.
lightly port it yourself with a dremel, no need to go crazy, just smooth out the inside of the runners.
Thanks for the input litle88 back to back dyno runs, same day, tuned for each...so the gain was from the intake.
i was very pleased with the results.
lost no power down low, rather gained it...noticably.
also moved my peak torque DOWN 500rpm.
and even though the cam is peaking at 6400...it still showed considerable gains.
the port job was minimal. never seperated the intake, was just what i could reach with a dremel.
Just have them install the injectors before the tune, it only takes about 30 minutes, instead of a tow (unless you got a hook up with that).
Dont forget to PORT it unless it already is.
Do you know what cam you want yet?
J/K man, me or Dubz are going to be your 11 second driver!Can't wait for the fast install!
