Got ARHs!!!!
Old Dec 17, 2009 | 02:24 AM
some_punk's Avatar
Default Got ARHs!!!!
Well some more stuff just arrived
American racing headers with all the emissions fittings and cats
Magnaflow catback
Diablosport predator programmer
And I bought this piece just for show a UMI driveshaft loop
This is what it sounds like now
http://www.youtube.com/watch?v=p1kkZpXJOts
A question i got is since it has rear o2 bungs, can i put the rear o2 sensor there and use a extension and not throw a code?
Old Dec 17, 2009 | 05:54 AM
toadzq8's Avatar
Merry Christmas! your going to like the ARH's best fitting set of headers I have ever owned. Tip, remove the trans cross member and lower the trans a bit, go right in. don't have to remove the oil filter or disconnect the steering coupling
Old Dec 17, 2009 | 08:00 AM
fatdave's Avatar
I have ARH on my TA and love them. You may still get a code with the O2's in. Has to do with them being moved further downstream. Messes with the reading that the computer is expecting if I remember right.
Old Dec 17, 2009 | 02:02 PM
toadzq8's Avatar
Yep! just plan on having the codes turned off on the down stream cats.
Old Dec 17, 2009 | 03:11 PM
Mumbles's Avatar
I installed my rear O2 sensors in my Jet Hot Catted Y-pipe.
I didn't need any extensions, so I don't believe you will either, in order for them to reach their locations on the Y-pipe.
I occasionally get an SES light. I believe it's PO420 , low catalyst performance or something to that effect. I erase the code and it may or may not show up again the next time I drive the car. Nothing worry about though. No loss of performance.
Be sure to post up when you complete your install. I can't wait to hear it. Good luck.
Old Dec 17, 2009 | 04:09 PM
02ArcticZ's Avatar
great headers love mine, enjoy yours.
Old Dec 18, 2009 | 02:09 AM
some_punk's Avatar
I have a set of o2 sims too, I am planning on plugging the real o2 sensors in, and plug the sims into the actual connector and then use some electrical tape to make it look like one unit, our air care system is run by idiots, so i am pretty sure that will fool them.
Old Dec 19, 2009 | 03:32 PM
dgcustomz's Avatar
They do look nice.. I am a kooks fan but to each their own. As for the rear o2's just get them deleted. I too would like to here how they sound after you install them.
Old Dec 20, 2009 | 02:20 PM
Engine_HP's Avatar
hard core
Old Dec 25, 2009 | 02:06 AM
some_punk's Avatar
Passenger side in
I managed to get both sides in without removing the coil packs, and I also managed to use a torque wrench on all 12 bolts doing first pass 11 ft-lb and 18 on the second.but the last 2 bolts did take forever to reach those numbers.
http://www.youtube.com/watch?v=cpNzWAvZOj
It actually sounds quieter than my uncle's gt500 mustang and subaru sti.
Onto the cats and catback tomorow. I am having some problems trying to get the catted y on, the outside diameter of the header is almost the same as the catted y, would it be safe to heat the catted y with a propane torch to slide it in?
Old Dec 25, 2009 | 03:04 PM
wws699's Avatar
ran into the same problem with mine, ended up taking the Y pipe to a muffler shop and had them expand the joints so it would slip on easier
