Problems with the 6.0L....WTF
Old Dec 21, 2009 | 01:53 PM
camarizzle1AC's Avatar
Default Problems with the 6.0L....WTF
Ok here's the story...spun a rod bearing in my 98 z28 so i got a LQ4 to replace the LS1. I put long tubes, and a MS4 Cam and dual valve springs in it and bolted the LS1 intake and accessories to it and put it in. I didn't have the transmission in yet because I was waiting on my new clutch but I wanted to start it up to make sure it would run ok. It idled pretty good considering I couldn't drive it down the road to relearn the computer. Idled up and down slightly. Then one day I had it idling for a friend to hear it and it was idling pretty well, and suddenly it started to miss really bad and bog down and then cut out. I couldn't get it restarted right away and while cranking it would backfire and finally started back up but was running horrible. I hooked my scan tool to it and it had a dead miss on cylinders 3 and 5 only. I took the intake manifold off and when i did gas came pouring out of the throttle body. seemed like a half pint to a pint of gas. WTF is going on here? Has anyone run across this before? Why is so much gas sitting in the bottom of the intake? Do I have a huge intake gasket leak or something? Please save my sanity
Old Dec 22, 2009 | 09:15 AM
anyone?
Old Dec 22, 2009 | 09:35 AM
thunderstruck's Avatar
you didnt say that you replaced the pushrods
have you checked them ?
im guessing you might have two pretty mangled intake pushrods on cyls 3 & 5
Old Dec 23, 2009 | 03:58 PM
you know what, i do believe you are right haha. I didn't even think of that but it does make pretty good sense. I'll pull the valve cover when i get a chance and i'll update ya on the verdict. thanks man.
Old Dec 28, 2009 | 07:26 PM
gnasty1521's Avatar
Sorry to hijack, but what do pushrods have to do with gas in the intake?
Old Dec 28, 2009 | 08:37 PM
Texhotrod593's Avatar
well it almost sounds to me since it was actually just idling and for a bit when it happened. those 2 injectors could have stuck open. pushrods could give you a problem, because if the pushrod was bent(it would have to be bad enough to notice when putting the lq4 together, also causing a bad ticking!) then it could keep the intake valve from opening causing the fuel to back up into the intake. check all your sensors and fuses also . i know the engine sensor fuse which on the same circuit 4 just about all the sensors like map, maf, o2's etc could be blown causing a very over-rich fueling situation. let us know what you find out so far!
Old Dec 28, 2009 | 11:05 PM
gnasty1521's Avatar
Thanks for the answer, and I would love to hear what is found out as well!
Old Dec 30, 2009 | 01:50 PM
TooLateVTEC's Avatar
Sounds to me like the injectors stuck open on those 2 cylinders for some reason.
Push rods are a less-likely problem for this, IMO. Open headers or not, standing near the motor with it running you shouldve been able to hear the knocking/clacking sound the push rods wouldve been making to bend that much.
Good luck OP and let us know what you find.
Old Dec 30, 2009 | 02:07 PM
when my pushrods failed (and bad enough that one was in two pieces) i could not hear anything other then a miss (also had backed up fuel)
