Sell the BBK SSI for a FAST setup?
Yep, still on stock suspension and rear. I am not quite sure if its worth it to invest in a throttle body for the BBK and also a MAF.
Im glad I didnt order a FAST yet, still undecided on what to get. I just took it off the car too. If I do keep it, it only takes 30 minutes to put back on
Had problems with the bottom plate leaking so just welded it on. MY Tb from BBK was also hanging until i found out the idle screw was backed out too much when i hooked it up to a scanner.
you should be able to get your goal with the manual tranny
I would keep an eye out though, when I was looking for my 90mm tb I kept finding used 85mm on here for well under $200
I would talk to your tuner about the MAF before you get one, some tuners seem to hate trying to tune on aftermarket MAF sensors from what I've read on here, not to mention a great number of respected minds on this site don't believe that upgrade is necessary or even helpful until past the 500rwhp mark, but if you can get one for $50 and your tuner says its good to go then I would go ahead and get one
