bigger injectors needed?
Old Dec 29, 2009 | 01:14 AM
some_punk's Avatar
Default bigger injectors needed?
I installed ARH headers still have to install the catted-y and magnaflow catback. And now I am also planning on buying a fast 92mm intake and throttle body. I also plan on getting thunder racing's old man cam with comp cam and comp cams valve springs and retainers. Now would I need new fuel rails and injectors? Don't plan on changing the heads.
Old Dec 29, 2009 | 06:25 AM
69LT1Bird's Avatar
You won't need rails, just a little bigger injector. Call Jon at FIC, he will set you up.
http://fuelinjectorconnection.com
Old Dec 29, 2009 | 06:47 AM
teke184's Avatar
i'm running stock injectors on my setup
bigger cam than you're picking, and a FAST intake.
they ARE maxed out though...but never ran lean on the dyno.
Old Dec 29, 2009 | 08:59 PM
some_punk's Avatar
how about the fuel pump?
Old Dec 30, 2009 | 03:03 AM
Armageddon's Avatar
...with cheese.
Your fuel pump should be fine. Get some 36lb injectors. Stock rails.
The 42lb green top Bosch injectors can be had for a fair price. You wouldn't need them... but they're just as easy to tune as a 36lb and you've got room to grow.
