Ported LS6 Intake?
Old Jan 5, 2010 | 05:17 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its probably safe to say that if you can port it to 85mm and pick up an 85mm TB that there is some power to be had. Engines are just a giant compressor. More air in more out.
Old Feb 15, 2013 | 08:40 AM
ws6man29's Avatar
Originally Posted by LS1-450
That's not true. I have spent alot of time testing & commenting on the subject & am don't spen much time re-stating the findings. Basically, an LS6 peforms best when ported to 85mm w/ an 85mm TB. The last mod that should be performed on an LS6 intake is a runner porting. First are filter, TB, CA intake size, then 85mm MAF, LS6 opening to 85mm w/85mm TB. Only port runners if you have tuning software that measures & confirms that the runners are a restriction. This won't be the case until using high flowing heads w/ an aggressive cam. Even when the runners become a restriction, it doesn't take much porting to get them where they need to be.
Hey.Can you tell me how you ported your ls6 intake to an 85mm.What do I need to do and what tools do I need.Also any tips??
Old Feb 15, 2013 | 12:14 PM
PREDATOR-Z's Avatar
You can change the intake snout and run a 90mm tb.
TPIS has a kit.
Old Feb 15, 2013 | 11:25 PM
*02WS6TURK*'s Avatar
Originally Posted by 01ssreda4
Dont phuk with the LS6. Leave it the hell alone.
Exactly. Waste of time and energy. Save up for a FAST.
Old Feb 15, 2013 | 11:52 PM
Fry_'s Avatar
I'm not sure which is a bigger waist of time, porting a LS6 intake or bringing a 3yr old thread back from the dead instead of using the search button. I've searched this before, yes it can be done, and the 85mm TB is probably worth a few Hp but not that much more than a properly ported stock TB. If you've got good enough heads that a LS6 intake is holding you back then just buy a fast and be done with it.
