LS1 removal
Old Jan 11, 2010 | 03:13 AM
brooknasty's Avatar
Unhappy LS1 removal
Anyone removed an LS1 with jackstands and jacks? Don't have access to a lift. What do I need? Thanks guys.
Old Jan 11, 2010 | 03:24 AM
lemons12's Avatar
Pull it through the top.
Old Jan 11, 2010 | 08:49 AM
01ssreda4's Avatar
Bottom for the win
Old Jan 11, 2010 | 08:50 AM
01ssreda4's Avatar
https://ls1tech.com/forums/generatio...ls1-fbody.html
https://ls1tech.com/forums/generatio...ne-bottom.html
Old Jan 11, 2010 | 09:29 AM
Joshiedoom's Avatar
Remove hood, use Strut tower brace hooked to cherry picker. The bottom is the "correct" way.
Old Jan 11, 2010 | 04:33 PM
Atver300's Avatar
Out the bottom with just a floor jack and jack stands, but it was a wrecked car so i wasnt worried about hurting anything.
Old Jan 11, 2010 | 05:14 PM
brooknasty's Avatar
Awesome! Thanks everyone for the input and pics. I'll post pics of the damage I do!
Old Jan 11, 2010 | 05:23 PM
ZTwentyAteU's Avatar
Ive done it without a lift a LOT. My record is 45minutes
 Michael S. Palmer
Old Jan 11, 2010 | 06:44 PM
philsblwnz28's Avatar
take it out the top, simple....My record is 25 minutes
Old Jan 12, 2010 | 02:04 AM
lemons12's Avatar
Bull ****..
Old Jan 12, 2010 | 03:59 AM
02_camaroz28's Avatar
Originally Posted by lemons12
Bull ****..
+1...
I was gonna call it but I figured I would let you do it lemons lol
Video tape it next time...
Old Jan 12, 2010 | 08:07 PM
lemons12's Avatar
Originally Posted by 02_camaroz28
+1...
I got it covered!
Old Jan 12, 2010 | 09:35 PM
WhiteRhino's Avatar
Mine.
Old Jan 13, 2010 | 07:08 AM
Ws6kid.'s Avatar
Originally Posted by WhiteRhino
Mine.
Dude that color is very very nice.
Old Jan 13, 2010 | 07:10 AM
BlackScreaminMachine's Avatar
Internet Mechanic
i have always done mine via the Top. Never had access to a garage where I could back it half way out and use a cherry picker and lift up the body.
Just disconnect the trans, harness, lines, and remove the front radiator/ac set up, exhaust manifolds and pull her out. You can remove the intake to give some clearence and its not hard to remove those. Just becareful of the oil pressure sending unit.
Old Jan 13, 2010 | 07:15 AM
JL ws-6's Avatar
Race your car!
They come out thru the top with no problem. Taking it out thru the bottom sucks, you have to re-align the car every time that way, rebleed the brakes, and the car is now immobile, you can't move it around if you want to.
I'll take mine out the top, it's not that hard, you get under the car to drop the headers, starter and unplug everything you can, lower the car back on the ground, unhook everything that's on the motor (wiring harness, etc) then pull the radiator, pull the intake, then hook up a plate in place of the valley cover like the qtp plate, or make your own.... or use a chain across the front and back of the motor, and be done with it.
It's simple to do out the top, I don't think for a minute that it's any quicker out the top vs the bottom... either way it probably takes about the same time, but in the long run it's less work to do it out the top for sure.
After doing it both ways on these cars.. I can speak from experience.
Old Jan 13, 2010 | 07:24 AM
Jeff Smith's Avatar
How do those guys w/o lift out in record time. Show us videotape
I done on my Ls2 Camaro using lift up and easy job....
Old Jan 13, 2010 | 07:29 AM
JL ws-6's Avatar
Race your car!
I dunno about the 45 min, alone taking my time, I can get a motor out in a day, but I'm talking a stock motor with everything on it. It's still a job no matter. I forgot to mention dropping the tranny x member and tranny off. Not a huge deal, but still needs to be done.
I'll get pic's of my car up when it's back from the chassis shop, when I'm done, the motor/tranny will come out together out the top, and it might be possible to do it in 45 min, but that's a different deal, with everything that a street car has on it being gone.
Old Jan 13, 2010 | 11:30 AM
[QUOTE=WhiteRhino;12741220] Mine.
What color is that?
Old Jan 13, 2010 | 11:35 AM
01ssreda4's Avatar
Jeez, quoting pics FTL
