pacesetter LT install.. car = slower and boggy
car runs like crap now though.. seems slower then before.. also every single time i had to roll out from a light tonight.. car bogs, rattles(i assume the y-pipe), and rpms build up to normal..
I had the car LS1 edit dyno tuned by MTi before the headers.. i think they removed all the EGR checks..
2 things i think it might be..
rear '02 sensors are plugged in.. these are race style headers.. so the plug right there the cats use to be.
the front '02 sensors are not plugged in.. their just zip tied up. Or..
that the Y-pipe where it meets the header is right against the bottom of there car.. its just the way the headers hang.. their right up against the car almost touching.. maybe vibration causing a false knock? what would be good to put in there to keep it from rattling?
car does throw a Service engine soon light.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Horrible advice, don't listen to it. DO NOT run O2 sims up front, you want them in the rear only. The front sims do all the real work, running sims up there is the last thing you want. Pay 90 for the rear sims and zip tie them up, then plug in your front 02s. This will fix your problem indefinately.
Rob
Rob
you didn't plug in the front o2's....you should delete this thread, change your user name, and pray for forgiveness.
i knew exactly that was his problem the minute i read that line. take the PCM to MTI and have them turn off the REAR O2's
plug your fronts back in the headers (with O2 extensions or extend your own)
then you'll be fine.
without your front O2 sensors the computer is in "autistic mode"
other then the y-pipe banging i think its runnin alot better. sorry for the dumb question, appreciate the help.
Just kidding! To me it wasn't a dumb question because I learned also. I didn't know that the front O2 sensors where so important. Now knowing that I went ahead and ordered the O2 extensions with my headers. Thanks for taking the heat for someone else.
