Need Help with gauge install
Old Jan 23, 2010 | 07:15 PM
99corvette's Avatar
Default Need Help with gauge install
Ok i am installing a air/fuel and trans temp electrical gauges. Well the air/fuel will be no problem, but when i got the trans temp it says i need two sources of power and 2 grounds...im guessing one is for the sender and one is for the lights. But i guess my question is does both of them have to be on a ignition switch or just one? Thinking about tapping into the headlight switch for one but dont know which one it is...found everything else i need through searches except this. Just got me confused on 2 different powers. The air/fuel only needs one.
Old Jan 23, 2010 | 07:31 PM
BaddBird's Avatar
You should look at a wiring diagram before you start tapping into the powers and grounds to make sure your headlamp switch wiring doesn't run through the BCM.
Old Jan 23, 2010 | 11:07 PM
99corvette's Avatar
Oh alright. I dont get why it would?? Or how it would effect anything. Maybe you can elaborate one thatf or me. I do not know a lot about electrical. I just saw on one of my searches where someone else did that.
Old Jan 23, 2010 | 11:45 PM
BaddBird's Avatar
What car are you working on 99corvette or the fbody in your sig? If you tie into a circut that runs through the BCM and your gauge shorts out you will pop your BCM. But hey its your ride.
Old Jan 24, 2010 | 07:59 AM
99corvette's Avatar
Alright i gottcha. But if it is ran to the fuse panel..wont it pop the fuse first??
I am working on a 2002 Camaro. Will it hurt to run all 3 power wires to the same spot in the fuse box or will that overload it?
And one more thing. I heard of people getting there power from the cig. lighter, but mine works all the time not just when the switch is on...
Old Jan 24, 2010 | 09:57 AM
BaddBird's Avatar
[QUOTE=99corvette;12792845]
Yes on the power side of the circuit. But if you tie into an existing ground circuit there is no fuse to pop.What I m getting at is it is better to run a new ground circut. Tie them both into one new ground.
I would run the both lights on one key hot power source then run the gauge on another.
You need to use a key hot circuit.
Old Jan 24, 2010 | 10:43 AM
99corvette's Avatar
alright thanks. im thinking about grounding them under the hood where there is already a few grounds mounted. Will that be fine?
Old Jan 24, 2010 | 10:53 AM
BaddBird's Avatar
That will work.
Old Jan 24, 2010 | 05:08 PM
99corvette's Avatar
alright got just about everything installed. one problem though. the trans temp gauge reads max temp. as soon as i turn the key over??
Old Jan 24, 2010 | 06:37 PM
99corvette's Avatar
i figured it out. i had a wire crossed
