How big of a deal is the coating on headers?
Old Dec 23, 2003 | 05:15 PM
felton316's Avatar
Wrapping headers will make them rust out even faster, because the wrap will hold in all the moisture.
Roadrunner 45's Avatar
If you're worried about corrosion, don't wrap the headers- this will accelerate the corrosion.
If $$ is an issue now, buy the uncoated and strip off the crappy hooker paint as it will flake off the first time you start the car anyway. I started the car and saw all the wrinkled paint and chips flaking off, so I took the headers back off and bead blasted them. Paint them with a good hi-temp paint (Summit sells a Hi-Temp silicone paint that I used- lasted about 5k miles so far and still looks perfect).
When you get the $$ call HPC (high performance coatings) or Jet Hot and send them out to be coated. As I recall both Jet-Hot and HPC quoted me about $175 (but I don't exactly remember the $$).
Old Dec 23, 2003 | 05:23 PM
2002SilverWS-6's Avatar
Originally Posted by 99-LS1-SS
That sounds good considering I don't have $1000 to spend on a set of headers right now. I know that is the cheap way out but I want performance and it is hard to justify $800+ to my wife when she thinks the car is fine the way it is.
Wives are like that.
Old Dec 23, 2003 | 05:29 PM
MM98's Avatar
FWIW, HPC here in OKC I think charges $220.00 for ceramic coating longtubes in & out with lifetime warranty against surface rust. Prices should be about the same in other locations being they are a corporation.
Old Dec 23, 2003 | 10:08 PM
LawmanSS's Avatar
FWIW, Jet Hot quoted me $279 for ceramic coating a set of Kooks SS headers, inside and out...this included return shipping.
Old Dec 26, 2003 | 08:43 AM
black_knight's Avatar
So coated regular > non-coated stainless steel?
Old Dec 26, 2003 | 09:26 AM
1CAMWNDR's Avatar
Talking
For me I could care less how the headers look. If they rust on the surface, great, that will look almost sleeper. I plan on getting some plain Pacesetters sometime this year if I am lucky, and will sand them then get some high-temp black paint and be done. Or I might go over the black paint with some rust colored paint.....
I just don't want the flash of ceramic or stainless steel in my engine bay. And the power difference is minimal unless you are already turning 450+ rwhp and are tuned untill your eyes water.
Old Dec 27, 2003 | 05:13 PM
lsx24's Avatar
I've heard wrapping the headers theoretically helps, but for some reason people have not had good luck/results doing that.
