1 7/8 headers?
Old Jan 29, 2010 | 04:44 AM
98LS1auto's Avatar
Default 1 7/8 headers?
Guys I have 1 3/4 Pacesetters on my car right now. I will be putting in a 383 in the near future. Would it be better if I go to 1 7/8 headers for the larger motor? Thanks.
Old Jan 29, 2010 | 07:44 AM
jam01's Avatar
i would say not necessary unless you are going with a good flowing set of heads intake and cam. even then they may move the power band higher in the rpm range than you need, unless this is mostly a track car.
Old Jan 29, 2010 | 08:12 AM
teke184's Avatar
you'll get more power
whether that power is worth the cost/effort is totally up to you
Old Jan 29, 2010 | 09:39 PM
98LS1auto's Avatar
Its a weekend warrior. But will see some track time. Motor has a GT2-3 cam, LS6 heads that have been worked. I also have the Fast 90/90 already which I will be putting on the motor. I'm eventually going to put either a Maggie or ProCharger on there also but not right now.
Old Jan 30, 2010 | 07:20 AM
jam01's Avatar
on the info you just gave, i will change my opinion to yes. upgrade to the larger header, have fun with it.
Old Jan 30, 2010 | 08:52 AM
BAD2000TA's Avatar
I'm confused. Are you aksing about headers for the current motor or for the 383? Are you planning on using the GT2-3 cam with the 383? That is a very very small cam on a 383.
The 383 will benefit with the larger headers. Your current motor will likely only see slight gains above 5500 rpm and may lose low-end torque compared to the 1-3/4" headers.
Old Jan 30, 2010 | 09:59 AM
TXZ28LS1's Avatar
i have pacesetters and i also have plans to do a 383. if i do go with the 383, i plan on running ARH 1 7/8 headers. so yeah, i would go with some 1 7/8 to get as much out of that setup as possible.
Old Jan 31, 2010 | 12:37 AM
98LS1auto's Avatar
I'm talking about the 383. The motor I'm buying is set up for forced induction. That may be why the smaller cam is already installed. I know with FI you don't run as large a cam as with NA. But I'm no expert on this stuff. Maybe I should swap in another cam before I install the motor. I'll ask the guys in the FI section. What do you think?
 Michael S. Palmer
Old Jan 31, 2010 | 02:45 AM
brian_rs/ss's Avatar
when you say "worked" heads what do u mean? ported? milled? hit with a sledge hammer?
it's hard to give you a good answer when you give vague discriptions.
if its just ls6 heads, low boost, and that small cam, i'de say the 1 7/8 headers are too expensive for the gains.
however if you are running stage III cnc ported ls6 heads, high boost, and a nasty cam then i would say yes 1 7/8 would be worth the extra green.
Old Jan 31, 2010 | 06:51 AM
98LS1auto's Avatar
They are Mallett ported heads with 67cc chambers, stainless valves. Don't know if that gives you enough info or not. If not I can try and find out more. Thanks.
Old Jan 31, 2010 | 10:44 AM
Top Fuel's Avatar
get the 1 7/8's. You'll see decent gains now and with cubes/blower its a no brainer.
