help with Y pipe beating the **** out of my car
http://www.ws6project.com/user_stor/...oducts_id=1796
Other guy's solve this problem by getting new motor mounts installed.
thanks man, im sure that works but are there any "free" ways of doing it? if not, than i'll pick this up.
I've done the heater hose thing and it stopped the banging but it created a vibration.
I took it back to the shop that installed it and they loosened the clamps and used a pry bar to pull it away from the car where it bangs and then retightened the clamps. So far it has worked fine.
free way would be to clearance it with a "dent" which works well.
but the best way is to install poly motor mounts. i did that and now run my exhaust 1/4" from my frame and never have banging.
do it right
You can cobble together something as a remedy or you can solve the problem as the included posts suggest.
Upgrade your motor mounts to either Poly's or Solids. It's a PITA, but there is a really great write-up on here you can follow and you'll be glad you did it once you've finished.
Here's the writeup. Good luck, man.
https://ls1tech.com/forums/generatio...r-written.html
