is this normal (pic inside)
Old Jan 29, 2010 | 07:03 PM
TrueMuscle=WS6's Avatar
Default is this normal (pic inside)
i dont know if this is normal for not but this is a pic of my car at an idle and the oil pressure seems pretty high
my bad the one on top is actually my car going about 60 mph
Old Jan 29, 2010 | 07:04 PM
Trans Am Jam's Avatar
none of these gauges are accurate. .i never rely on them
Old Jan 29, 2010 | 07:05 PM
and this one is my car at an idle
Old Jan 29, 2010 | 07:06 PM
are you sure sometimes it will almost get to 80
the oil pressure that is
Old Jan 29, 2010 | 07:13 PM
blk00ss's Avatar
Wrong section. But that's fine...and I've found the factory pressure gauge to be pretty accurate. It's not going to be off more than 5psi. Which wouldn't amount to much anyway.
Old Jan 29, 2010 | 07:19 PM
so is mine off or not
 Michael S. Palmer
Old Jan 29, 2010 | 07:22 PM
or should i say what is it suppose to be at. and if you let it seat a while longer the pressure goes to between 40 and 60 but when you drive it goes back just a little over 60
Old Jan 29, 2010 | 07:33 PM
Joshiedoom's Avatar
There is no set pressure. There is too much and there is not enough. Your fine.
What type of oil do you run?
Old Jan 29, 2010 | 07:38 PM
MeentSS02's Avatar
Kleeborp the Moderator™
To me, that looks normal. At idle just after started, my oil pressure gauge reads around 60 psi...after it is fully warm (oil temps 210+), the pressure at idle is usually around 40 psi or so, and cruising goes right back up to around 60 psi.
I'd only start shitting myself if it was reading really low.
I'm also going to move this to Gen III External Engine instead of the Fueling section.
Old Jan 29, 2010 | 08:05 PM
Ironxcross's Avatar
Yep, exactly what you put. 60 at idle on start up. 40 at idle when warm, 60 when cruising. I use 5w-30 conventional like the manual says.
Old Jan 29, 2010 | 09:28 PM
Engine_HP's Avatar
looks fine to me, mine reads up to 3/4 @ cold starts.
Old Jan 29, 2010 | 09:46 PM
MattxFatal's Avatar
Same here.
Running GC 0W-30.
Old Jan 29, 2010 | 11:18 PM
02CamaroSSLE's Avatar
yeah that is about normal... i heard somewhere the min oil pressure is 10psi per 1,000rpm but i think we exceed the min by far! (dont burn me if im wrong though...)
Old Jan 29, 2010 | 11:51 PM
Quik Sand's Avatar
Looks okay but the oil pressure sending units frequently give our cars problems
Mine hangs around 40 once warmed up. Think its closer to 60 on cold cruising.
