PS pump issue
BTW I have streel braided PS lines.
-Putting the front end in the air
-Fill reservoir to proper level
-ENGINE OFF, turn the steering wheel lock to lock 20 times. As in, turn all the way to each lock, 20 a piece
-Put the car back down, repeat above procedure one more time with the engine RUNNING
-Fill reservoir as needed. Have someone stand over the reservoir with the cap open while you turn the wheel a few more times. Check to see if there are any more air bubbles. If so, repeat process as long as needed until there's no more air bubbles.
If you didn't do what I just listed, you probably blew some **** up.
I got the pump off, is there anyway to check to see where its leaking. Looks pretty sealed aside from the connections to the reservoir and the seal behind the pulley.
