What header gaskets and bolts do you use???
Old Feb 1, 2010 | 08:11 PM
blubyu02's Avatar
Default What header gaskets and bolts do you use???
I have hooker headers and about two months ago i got an xhaust leak, it wasnt bad but now its freakn annoying. i replaced the thick gaskets that were on the car w/oem gm gaskets and bolts and that didnt do the trick. now i just want my car back, what gaskets and bolts keeps y'all quiet??
Old Feb 1, 2010 | 08:18 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Stock GM gaskets and ARP header studs here...
Old Feb 1, 2010 | 08:28 PM
blubyu02's Avatar
also does anybody run lock washers on there header bolts? should i get shorter bolts?
Old Feb 1, 2010 | 08:32 PM
MeentSS02's Avatar
Why would you want shorter bolts? So it is easier to strip out the threads in the heads?
Old Feb 1, 2010 | 08:38 PM
blubyu02's Avatar
i was thinking that my hookers were thinner than stock, maybe thats why my leak keeps coming back, i would do ne thang for it to stop its so dang annoying.
Old Feb 1, 2010 | 08:42 PM
MeentSS02's Avatar
I see what you are getting at...I'd seriously look into header studs. The stock GM gaskets are really very nice.
Old Feb 1, 2010 | 08:59 PM
blubyu02's Avatar
man im begging like a step kid gettn a whooping from his step dad while mama at work for this leak to stop, its leaking on both sides, sounds like a clock under the hood. ima go order the arp's and pray that works i got some lock washers for headers at advanced auto debating on using em'
Old Feb 1, 2010 | 09:15 PM
mike135531bubba's Avatar
i used brand new gm gaskets and re-used some of the original bolts even. are you tightening from the center out?
Old Feb 1, 2010 | 09:19 PM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
so should i NOT use the gaskets hooker sent me with the header purchase...what about the bolts they sent me....also i have been told to use the gaskets that are already on the car and it will be fine is this true ? and how should i tighten them because i dont want to strip anything
Old Feb 1, 2010 | 09:35 PM
HitmanLS1's Avatar
I used my stock stuff and its working just fine.
Old Feb 1, 2010 | 09:41 PM
blubyu02's Avatar
no i wasnt aware of the center out method, i am taking my time cuz i dont want to strip any of them, ive been reasearching and the stage 8 lockling bolts seem to be good and a favorite as well as arp
Old Feb 1, 2010 | 10:03 PM
SweetS10V8's Avatar
I think that the general rule for everything, automotive or not.....
