What bolt on should I buy next?
Old Dec 24, 2003 | 02:05 PM
Ryan Boechler's Avatar
Default What bolt on should I buy next?
Hey guys, got a couple questions for ya.
I'm 19, own a 01 SS, I'm somewhat on a limited budget and also have warrenty on my car until 2006, so obviously I can only do bolt ons. So with that said, I'll tell you what mods I have so far. I have a TSP Smoked Lid, SLP Bellows, BMR STB, Lou's Short stick, I have ordered the GMMG Chambered exhaust, and was wondering what else I COULD do that would be a good mod that wouldn't void warrenty. I was thinking headers, but I don't know what would void and what wouldn't...... By the way I live in Canada so the warrenty is different then you US guys.
Thanks for the help....
Old Dec 24, 2003 | 02:22 PM
DeepBlueZ's Avatar
maybe some 4.10s???? I dont know but those SHOULDNT void the warranty...
Also You'll see a ton of performance out of a set of drag radials and those are as bolt-on as you can get.
Old Dec 24, 2003 | 02:40 PM
WS6FirebirdTA00's Avatar
i would do headers, maybe some more suspension stuff. do all the free mods too. i hear what your sayin im 19 too and im tryin to figure out the best bang for the buck thats cheap. u can pm me for any more info if u want. only bolt ons i have left to do is intake and EWP but i hope to be done by summer with all that
Old Dec 24, 2003 | 03:09 PM
DARK AGE 53's Avatar
Ryan, The SS's run great right out of the box so I would do suspension mods first, here's what I have . Bilstien shocks, BMR PHR, tubular LCA, front and rear sway bars with there poly-end links, as far as SFC go I would suggest SLP's bolt-on's.
Al
Old Dec 24, 2003 | 03:12 PM
why front sway bar? they come with 32 mm stock? it has the same spring rate at the 35mm just the 35's are lighter. i would definatly do the 21mm rear bar, control arms, all poly bushings, torque arm, panhard, sub frame connectors. there is a lot to do on the suspension, nothing but the aarms are stock on mine
Old Dec 24, 2003 | 03:17 PM
Sniper33's Avatar
I say some weld-on SFC's. I have BMR tubulars and they are great. Should be the first mod for all these cars (other than a lid).
Old Dec 24, 2003 | 03:20 PM
Will SFC's void warrenty? I can't imagine they would, but I'm not sure.
Old Dec 24, 2003 | 03:30 PM
If you go with weld-on's they may void your corrosion warranty in that area, the bolt-on's won't void any warranty. BTW, where in Canada do you live?
Old Dec 24, 2003 | 03:38 PM
Saskatchewan.
Old Dec 24, 2003 | 03:53 PM
Jorday's Avatar
Yah, you could try headers. That's probably what I would do next.
Old Dec 24, 2003 | 04:17 PM
shouldnt void it if u get it done right and repainted where it cant rust
Old Dec 24, 2003 | 04:18 PM
i had MAF and programing and it didnt void my warranty, but they didnt know about the programing cause it was brought in for a fried pcm lol
Old Dec 24, 2003 | 05:30 PM
The Guy in MY 99TA's Avatar
Like said above with the suspension stuff. But I'de go with weld ons, that shouldn't bother the warranty a bit.
BUT if you want a performance mod get a Predator programmer. Its the closest thing you can get to LS1 edit and there really isn't much difference as far as what you can do with it.
Josh S.
Old Dec 24, 2003 | 06:03 PM
JDPZ28's Avatar
Headers are a good idea. I was also thinking 4.10's or a Pro 5.0 to compliment the
LSS. Drag radials also help you hook up a lot better.
Old Dec 24, 2003 | 06:56 PM
I have Lou's Short Stick, isn't that better then the "Pro 5.0"?
Old Dec 24, 2003 | 06:58 PM
S2002S's Avatar
Bolt on SFCs
Cold Air Induction..
Old Dec 24, 2003 | 07:07 PM
what shifter do u have with the short stick? hurst? if so then dont mess with it, maybe get an MBA shift **** but tahts what i have and i like it a LOT better than my friends pro 5.0. throws are shorter too
Old Dec 24, 2003 | 07:44 PM
Ya I have the stock Hurst with the Lou's Short Stick....... I love it........ the throws are the smallest of them all.
What's the difference between the Predator Programmer and the LS1 Edit?? Price? Don't they basically do the same thing? I'm not sure I've never really read up on them.
Old Dec 24, 2003 | 08:43 PM
yeah they are the same pretty much just the predator u have someone else tune it for you. edit is good if u have time to learn how to do it all but if u dont know much or wanna learn get predator its real easy and just as good. i have it and love it to death and would buy it again. i would wait to get that until they get the new one with loging though
Old Dec 24, 2003 | 09:55 PM
demonspeed's Avatar
It's not mine! woo hoo!
Drag Radials
Then i'd ditch the Hurst and go with a Pro 5.0, subframe connectors and lower control arms. That should be a great setup for the street and the track.
