Which rods are stronger?
Old Feb 7, 2010 | 12:33 PM
IKnowtheFuture's Avatar
Question Which rods are stronger?
The Eagles:
http://speed-eng.com/store/eagle-rod...in-p-6678.html
Or..
The Compstars:
http://estore.websitepros.com/2120533/Detail.bok?no=82
on eagles website, It said that with the L19 bolts they are rated for 1400hp.
I dont know about the comps
Old Feb 8, 2010 | 03:24 AM
t t t
Old Feb 8, 2010 | 06:44 AM
Gordon0652's Avatar
What are you looking to do?
Old Feb 8, 2010 | 08:09 AM
mike13's Avatar
I don't know which rod is rated higher but I like the compstar H beams of the two. Just based on reputation.
Old Feb 8, 2010 | 02:44 PM
I am rebuilding my motor for my turbo build. I am going to be running between 700-800rwhp and try to get up to 900-1000 later on. I am Keeping my stock crank (347) and want my compression ratio around 9-9.5:1 I think. I am going to be running a multi-stage boost controller and probably a quick spool valve also, so I can run no boost or 20 lbs of boost and every where in between.
Old Feb 8, 2010 | 05:30 PM
SOMbitch's Avatar
I like the compstars a little better because they are usually good to go out of the box. I have seen some Eagles that needed a little work to make them ready. Other thanthat I would say they are pretty equal...
Old Feb 8, 2010 | 07:40 PM
Gordon0652's Avatar
Compstarts with ARP 2000 bolts.
