Wont Run, please help.
Old Feb 12, 2010 | 07:41 PM
TPRDFW's Avatar
Default Wont Run, please help.
Car was parked outside and had about 5 inches of snow on it now when i go to start it it sounds like it is running on 2 cylinders and it misfires and pops.
im hoping that i didnt get something under the motor bay wet. im going to start by changing the plugs and o2 sensors. any other ideas?
what would happen if the pcm got wet?
Old Feb 12, 2010 | 07:50 PM
TPRDFW's Avatar
btw no codes i cant keep it running unless i give it alot of gas.
Old Feb 12, 2010 | 08:52 PM
twelver12's Avatar
strange for sumthin like that to just happen, you sure this wasn caused by you in some way?
Old Feb 13, 2010 | 03:49 PM
TPRDFW's Avatar
no im positive. its like someone ****** drove it or something. i noticed my car had to be jumped and my fuel pressue was at like 40psi normallly around 60
Old Feb 14, 2010 | 12:33 PM
crainholio's Avatar
Water in the gas, froze up due to the cold.
Old Feb 14, 2010 | 04:36 PM
TPRDFW's Avatar
ur a genius i believe u.... what should i do?
Old Feb 14, 2010 | 05:24 PM
crainholio's Avatar
Put the car into a heated garage and let it sit overnight.
Add a bottle of fuel additive for this purpose, usually labeled "Gas Dryer" or similar found on the additives shelf at the parts store.
Then use the 2sec prime function to circulate it to the rails. Turn the key to RUN, let the pump run for a few seconds, then back to OFF. Wait ~10sec or whatever, then repeat. Continue doing this for ~20 repetitions, without starting the engine.
Then start the engine and keep it running for a few minutes, see if it clears up.
Old Feb 14, 2010 | 05:26 PM
TPRDFW's Avatar
thanks any other ideas? do i have to drain the tank?
Old Feb 14, 2010 | 05:30 PM
crainholio's Avatar
Draining the tank won't help, ice usually forms in the fuel lines.
Old Feb 14, 2010 | 06:58 PM
99huggerorangeZ's Avatar
mr mouse and his family been living in your engine bay chowing on your fuel injection harness or ignition harness?
Old Feb 14, 2010 | 07:03 PM
TPRDFW's Avatar
how can gas freeze then? i dont get it...
TPRDFW's Avatar
and no i have no mice in my engine bay
Old Feb 15, 2010 | 05:43 AM
crainholio's Avatar
Short memory? I posted this:
Old Feb 15, 2010 | 09:06 AM
TPRDFW's Avatar
Achocol wont freeze so im sure gas is the same way rright?
Old Feb 15, 2010 | 05:22 PM
crainholio's Avatar
Most alcohols and gasolines won't freeze at the temps we're seeing.
However, any water that might be in your tank and fuel lines very much will freeze. And when it does, it will block or reduce fuel flow to your injectors.
I am just guessing at what's wrong with your car, it's nearly impossible to accurately diagnose car troubles via the Internet. Based on what info you've provided it sounds like water contamination in your gas.
Old Feb 16, 2010 | 08:29 AM
TPRDFW's Avatar
thanks for the help
Old Feb 17, 2010 | 12:27 PM
TPRDFW's Avatar
problem solved thanks guys
Old Feb 17, 2010 | 12:57 PM
what did you find out?
Old Feb 17, 2010 | 03:38 PM
TPRDFW's Avatar
idk went bak four days later put some heet addicitive water remover in it and it fired up with 24more rwhp
Old Feb 17, 2010 | 07:46 PM
crainholio's Avatar
Congrats!
I'd find a different gas station from now on...
