EGR Bypass Confusion
Old Feb 13, 2010 | 12:49 PM
danbrazda's Avatar
Default EGR Bypass Confusion
I bought a used 2001 WS6 which I have read does not have EGR. Previous owner has some kind of home made bypass going on and I'm wandering what it is. Passenger side front of intake has hose going out of it and is t'd with hose coming from rear of engine and up along the valve cover on that side. This jerry-rigged contraption routes through what looks like a pcv valve and then through a filter before dumping down to the ground.
I'll post pix if this is way too confusing but maybe someone can just tell me wtf this sounds like. A Performance shop told me it is a home made egr bypass- but it's a 2001. Ideas anyone?
Old Feb 13, 2010 | 01:15 PM
nemss1's Avatar
doesnt sound like an EGR bypass to me, considering 01-02 do not have EGR. sounds like some sort of PCV contraption
Old Feb 13, 2010 | 01:27 PM
danbrazda's Avatar
Here are the two hoses- intake on right:
And here is all the crap I took off to figure out what the intention was:
Old Feb 13, 2010 | 01:53 PM
nemss1's Avatar
the hose in the first pic is supposed to go the the barb on the intake
the 2nd pic, is extra crap and is not factory
Old Feb 13, 2010 | 02:12 PM
danbrazda's Avatar
Yeah I think the intention was to keep exhaust gases or oil from re-entering the intake? I've seen posts about catch cans and wonder if this was an attempt at a poor man's version? I'm a bit confused still as to the "dirty side" vs the "clean side" as well as why this jerry-rigged setup ends with a hose that just dumps out the bottom of the car.
Old Feb 13, 2010 | 02:31 PM
Joshiedoom's Avatar
This is a homemade catch can setup. You need the pcv system and a catch catch it seems(lots of oil)
Old Feb 13, 2010 | 02:43 PM
01'SSLSX's Avatar
^+1 yeah, its just a home-made catch can for PCV system
but buy a real one
i dont think i would use those mechanics u talked to anymore!
Old Feb 13, 2010 | 02:48 PM
Joshiedoom's Avatar
but buy a real one
I agree with both statements
Old Feb 13, 2010 | 03:10 PM
danbrazda's Avatar
Agreed on the mechanic in question.
Help me understand how this setup was supposed to work though. The catch can setup is very simple- one tube in, one tube out. I'm not putting this silly puzzle back on the car but when I look at the hoses and t's and couplers and filter (2nd pic above) I don't see the logic as to how it worked in the first place.
Can anyone put the pieces back together in a logical manner?
Old Feb 13, 2010 | 03:29 PM
Nemesis350's Avatar
honestly, it's really not even worth wasting time on. If you want you can do a google search on homemade catch cans and you'll see a bunch of what you pulled out from your car. I thought about trying it once, but it looks god awful and not so practical in the long run.
Just reconnect the pcv lines back into the intake for the meantime, until you get a catch can. Trust me you wont regret it. BTW you should do a search to see other things you can do to improve the pcv system, such as breathers
Old Feb 13, 2010 | 04:09 PM
Joshiedoom's Avatar
Yes.
You need the t and the pcv system because the stock stuff is plastic junk. It is critical to the operation and idle of the car unless otherwise tuned out.
I will make you a diagram.
Old Feb 13, 2010 | 04:19 PM
Joshiedoom's Avatar
http://i249.photobucket.com/albums/g...iedoom/pcv.jpg
Old Feb 13, 2010 | 05:11 PM
danbrazda's Avatar
Thanks guys. So until my catch can is in hand, I just hook it up like in Joshiedoom's diagram right? When I get the catch can, then the pcv valve goes into the catch can and then I go out the catch can into the intake.
Old Feb 13, 2010 | 05:12 PM
Joshiedoom's Avatar
You are 100 percent correct ! Goodyear fuel line is also emission line btw if the fear of not passing emissions comes up. If anyone has that problem
Old Feb 13, 2010 | 05:30 PM
danbrazda's Avatar
Anyone have an opinion on this mod from "joecar"?
https://ls1tech.com/forums/generatio...out-one-3.html
Old Feb 13, 2010 | 05:44 PM
Joshiedoom's Avatar
Wow good link. Only thing I worry about is the fact that it doesnt have baffles and its not pulling from the other valvecover. It would still use a ton of oil
Old Feb 13, 2010 | 05:57 PM
WizardofDetailing's Avatar
Besides the pcv stuff, did anyone notice that the first pic looks like the throttle body coolant line is missing. Even if that is bypassed, shouldn't it be capped off?
Old Feb 13, 2010 | 06:00 PM
Joshiedoom's Avatar
The caps only prevent dust and debris from entering. I have run my uncapped since day 1.. and thats been a lot of miles and a few years.
Old Feb 13, 2010 | 07:59 PM
danbrazda's Avatar
Joshidoom, what catch can are you using? How much oil do you use between oil changes?
Old Feb 13, 2010 | 11:29 PM
Joshiedoom's Avatar
I have the 98 valve covers and use a truck fixed orifice pcv valve system. I have NO oil usage at 169k. Though I would go with a rev extreme or the ws6 store catchcan. You get what you pay for.
